Thread: Suggestions for Spa Pump Replacement
    Apr 2013
    Phoenix, AZ
    5
    Spa pump (Hayward Super II, 1.5 HP, can't read SF) has bit the dust. Impeller is rusted onto motor shaft. Thinking of replacing whole pump (close to 20 years old).
    Would appreciate suggestions on a replacement.
    Recently replaced pool pump with Pentair Superflo VS 342001. Would it make sense to replace spa pump with another Pentair 342001, primarily for replacement purposes in case one of them would fail?
    Spa has 6 jets, aerator, sits about 18 inches above pump and 20 feet away from pump.
    12,500 gal inground pebbletec pool w spa spillover; Pentair Superflo VS 342001 pump; 1.5HP Hayward Super2 booster for spa jets; 3.1 Hayward sand filter; gas heater; 2x suction PoolCleaner
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Suggestions for Spa Pump Replacement
    Doesn't sound like a bad idea to have two of the same pump assuming you like it.
    Being VS, as you know, you have a lot of options in how to run it.
    However, the spa could likely use a much smaller pump and therefore it would be cheaper.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I don't know if you want the expense of a VS pump to run a spa. I am very high on VS pumps for the savings and flexibility they provide, but you generally run a spa at one speed and one speed only. Also, you won't be running it for several hours, like your main pump. So you will never see any savings to offset the additional cost, nor will you have need of the added flexibility that a VS pump provides.
    chiefwej
    Jun 2015
    Wildomar, California
    423
    If your pump just runs the spa jets, a VSP would be overkill since you only run one speed.
    Mar 2015
    Sugar Land , TX
    424
    Is there anyway you can change your plumbing to use the VS for both pool and spa? You could add a valve to change from one to the other.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Apr 2013
    Phoenix, AZ
    5
    Good input so far. Looks like a single speed pump replacement is a few hundred less than the VS pump - and I probably will only run it at one speed. Re changing plumbing, not sure current VS pump would be powerful enough. Pool repairman thought I'd probably need a 3HP Intelliflow to pump to spa and pool at same time.
    Anyone know of a single speed pump with a built in timer that might work as a replacement? Would be nice to be able to circulate spa water nightly.
    Forgot to say in last post - heater is plumbed off of pool pump, also has a line to the spa.
