Thread: Convert Fiber Optic light port to suction port for cleaner in Fiberglass pool
    I have a broken fiber optic strand going to an eyeball port in a fiberglass pool. I'm not totally for getting a new housing. I would much rather have a dedicated suction line for the cleaner.
    Assuming I can get plumbing to the port, can this be easily converted to a cleaner suction port?
    _____________________
    15K IG Fiberglass
    IC40 + Easytouch + Superflow 1 HP 2 speed
    Sherlok 120, MaxETherm 200 HD Heater, Southeast Michigan
    Re: Convert Fiber Optic light port to suction port for cleaner in Fiberglass pool
    Any thought on this?
    15K IG Fiberglass
    22,553
    I don't know how easily it can be converted, but it's certainly possible. I'm not completely sure that the light lens is the same threaded configuration as a standard 1½" eyeball fitting, but it may be.
    I tried a return jet eyeball, and it definitely fits.
    I took a picture of the port, and where the 'flexible pvc' pipe comes out of the ground. There is no marking on it. Is there any way to tell if this is
    'suction rated'? If it is, it is about 10 feet of digging to get back up to the pump inlet.
    15K IG Fiberglass
    22,553
    That looks flex PVC and if it is then it's rated for 28"HG vacuum.
