Results 1 to 14 of 14
Thread: Fill Water Test - Advice needed
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Hey folks...newbie here. So we are putting in a 24' AGP and I ordered the TF 100 kit. Couldn;t wait to test with it so I figured why not test my tap water, which I plan to use to fill the pool. Here are my results as they were somewhat surprising. We live in Dutchess County NY and we always knew our water was hard, but this seems off the charts. Please let me know if it is possible to use this water for fill or will I be better off spending $700 for 3 truckloads of water (would rather spend the money on Trex :>))
    PH - 7.2
    CH - 470 (Checked twice 1st reading 460)
    FC - 0
    TA - 360
    Didn't test for the remaining stuff as I figure I should be able to adjust.
    Great site and can't wait to get some feedback!
    Re: Fill Water Test - Advice needed
    Welcome to TFP!
    It is possible to work with those levels, but it will take lots of acid and some diligence at the beginning to keep the PH carefully controlled until you can get the TA down. You will also want to use every opportunity to gather rain water to keep your CH level from going up too much over time.
    If you are thinking about getting water trucked in, first double check that the water you are getting won't have exactly the same problem.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If the trucked in water is good, what about a 50/50 mix? That might work...
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Thanks Jason..that's what I was fearing as well about having water trucked in...this region is well known for hard water.
    I am assuming I should just follow the sticky...lower ph to 7...aerate...repeat, repeat...we have about a month between install and swimming weather so that's not an issue.
    Is the CH level a concern for scaling or have you seen worse used for fill?
    Thanks again
    11,969
    Scaling can be avoided by keeping the PH below 7.8... and then collecting the rainwater like Jason said and trying to dilute the pool water down that way...
    Good luck!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Thanks so much guys...you rule! Also we are planning on plumbing in a intex SWG...will the CH impact the SWG in anyway if I make sure to keep the PH below 7.8?
    11,969
    The same scale you experience in other parts of the pool can render the SWG cell useless....just keep it below 7.8 and you should be o.k. I think...
    Guest
    Forst thing to do would be to work on the TA to get it down to acceptable levesl. This will take a lot of acid and a bit of time but once you do your CH should not be a problem. With a SWG you never want the pH to go above 7.8
    It is possible to manage CH levels up to as high as perhaps 1200 if you keep your TA level low and are very careful to make sure the PH never gets too high. As the CH level gets higher you may need to lower your maximum allowed PH to compensate. It is all doable, but does require attention to monitoring the PH level.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    You guys are great...kind of like the Mastercard slogan "priceless" Thanks again for all your assistance! I am SO glad I found this site.
    Regards,
    Denis
    Guest
    Quote Originally Posted by waterbear
    First thing to do would be to work on the TA to get it down to acceptable levesl. This will take a lot of acid and a bit of time but once you do your CH should not be a problem. With a SWG you never want the pH to go above 7.8
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Water bear and Jason...ty so much guys....TA is on it's way down...currently sitting at 250...ways to go I know...but my super aerator should get the job done ...check it out
    http://s702.photobucket.com/albums/ww30/dmanb2b/
    11,969
    Quote Originally Posted by dmanb2b
    You've been busy!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    yes I have...TA is down to 180 now
    I know I have a ways to go but I just love the TF100
    CYA 20 - still disolving
    FC = 6
    CC = 0
    PH = 7.2
    Waiting for my TA to get to the 70-90 area before I add borax...I feel like half my pool is filled with MA.
