Thread: Can a leaking spider gasket cause pump to lose prime overnight?
    My pump is losing prime overnight. Based on my understanding and reading here, this almost always is said to be caused by a suction side leak. However, there are no bubbles in the pool. The pump basket does seem to have a different sound than before acting somewhat like air is getting introduced. So I do plan to replace the o-ring on the lid.
    However I do know that I have a leaking spider gasket as I can see small drops of water that come out the waste. It has been this way for awhile. Is it possible the spider gasket is causing the loss of prime?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Can a leaking spider gasket cause pump to lose prime overnight?
    Yes. Your system, when off, might relax a bit and a leaky spider gasket could let air into the system and cause a loss of pump prime. When it is back on and under pressure, it might get sealed again for air but not water and hence the leak. The same goes for when off...it may not drip when off due to no pressure. Or it might leak water when off AND provide an outlet for air.
    If the leak has been happening for a while, the gasket is only going to continue to get worse.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
