Results 1 to 9 of 9
Thread: Help me size my filter
    Mar 2015
    Dallas, Texas
    133
    We are finishing our build on a 30x18 in ground pool. Approximately 17,000 gallons. We are required by our city to use a de filter. My question is the pentair 48 sqf big enough or are we better off with the 60sqf?
    Build in progress: 31x18 GI (17,336 gallons) / Diamond Brite French Gray finish / Flagstone Coping / 30ft weeping wall with 7 stations plumbed / Salt Finish Deck / Pentair EasyTouch Controls / Pentair IntelliFlo Variable Speed Pump / Pentair D.E. Filter 60sft / Polaris Automatic Pool Sweep w/ Booster Pump.
    38,463
    Re: Help me size my filter
    Being required to use a DE filter is mind boggling to me. What is the rationale? Usually DE would be the type that is prohibited, not required
    Anyway, given your location and that the pool will always be "open" get the 60 sqft.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I would love to see that regulation... can't believe that...
    bigger is better...
    Mar 2015
    Dallas, Texas
    133
    Ya it's crazy very small,city with weird rules. They won't allow cartridge unless you are on septic and want to make sure you are tied into the sewer line for backwash.
    Jul 2013
    Fletcher, OK
    3,353
    cartridge filters do not backwash, unlike DE and sand... unless you build it into your system like I did.. environmentally, DE is probably the most restricted and regulated of all filters...
    JoyfulNoise's Avatar
    May 2015
    13,247
    That's weird as you usually see filter regulations that require separation tanks, not exact filter types. The funny part is, you still need to tear down a DE filter regularly (like once per year) and do a deep clean of the cartridges or grids. You can backwash the filter prior to opening it, but that only gets rid of maybe 50% of the DE that you need to clean off. The rest comes off on your lawn or "back 40" when you take apart the grids/cartridges for cleaning.
    So in the end, the regulation is kind of useless since you will still be discharging DE into the environment...unless you plan on being a "good citizen" and figure out a way to capture all the DE crud you wash off.
    Matt
    Mar 2015
    Dallas, Texas
    133
    Completely agree. It's weird. Builder even talked to them and explained cartridge doesn't backwash but they are stubborn.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Definitely 60sqf. Oversizing will reduce frequency of back washing.
    Our 20k gal pool has a 60sqf DE filter and I can go all season (May-Oct) without having to backwash. So far this season filter pressure has only gone up 1lb.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Mar 2015
    Dallas, Texas
    133
    Thanks for the advice I went with the 60. Got installed just a few hrs ago
