Results 1 to 13 of 13
Thread: Drain and Refill to Correct CYA
    WalterE's Avatar
    Aug 2015
    Little Rock, AR
    37
    Following instructions from this forum, I have done a 1/2 drain and refill with city water. Would like some guidance as to what to do next in migration to BBB.
    Prior to Drain.. Pool was clear, but previously I had a couple of algae attacks and was using pool store advice with pucks and shock, with limited success and very high CYA. Ordered Taylor k-2006 and here are numbers prior to drain.
    FC 2.0
    CC 0.5
    PH 7.4
    TA 150
    CH 70
    CYA well over 100 (note: on Taylor it's half way between the 100 mark and the bottom of the tube)
    Just for info, I measured the city tap water prior to the refill.
    FC 1.6
    PH 7.3
    TA 20
    CH 30
    CYA 0
    Now here are my numbers after the drain and re-fill
    FC 1.0 right after refill
    FC 5.0 after 2 gallons of bleach
    CC 0.4
    PH 7.6
    TA 80
    CH 50
    CYA greater than 100 estimating 130
    Looks like several more half drains and refills to get CYA where it needs to be
    Would like some direction and help to ensure a smooth transition to keep me out of trouble.
    25,000 gallon in-ground pool - Vinyl Lining
    Hayward Pro Series S244T Sand filter -- 300 lb Sand
    Taylor K-2006 Test Kit
    Hayward Pump - runs 24x7
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Drain and Refill to Correct CYA
    Based on your TA and CH levels after the fill, you are getting very close to a half drain. I would do one more half drain and you should be close to 60-70 ppm CYA. One more would likely get it low enough for normal maintenance near recommended levels.
    After you've done one more, post results and we'll go from there. Read up in Pool School, specifically the CYA/Chlorine chart and other articles such as Recommended Chemicals, Recommended Levels, How to Chlorinate your pool, etc.
    Isolated Spa - 345 Gallons
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Hi WalterE, your reading of 0.4CC indicates you are using 25ml of water sample to test. If you only use 10ml water, you can save your testing reagents. Each drop would then equal 0.5ppm chlorine instead of 0.2ppm. The 0.5ppm precision is normally adequate.
    p.s. it looks like you have a great grasp of what you're doing so far!
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    WalterE's Avatar
    Aug 2015
    Little Rock, AR
    37
    According to the FreeChlorine/CYA chart, at a CYA of 100, I should have FC 7 minimum, 12 Target and 39 for SLAM. According to the PoolMath chart, to get to 12 from 5 would require 3 gallons, which would not be too bad, but to slam, would require 16 gallons. That makes me nervous. Would that damage my pool?
    100*
    7
    12
    39
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    No, it would not damage your pool, it is just a lot of bleach/chlorine to buy, haul and add. I had to slam earlier this summer with CYA at 70 and FC in the upper 20s with no issues. We swam the whole time. Our CYA is 70 because we have saltwater.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by WalterE View Post
    100*
    7
    12
    39
    you are correct about your concerns about SLAMing levels. but you also do not have a CYA of 100, it is 100+. it could be 110, it could be 150. you need to do another drain until the CYA test is within range...i.e. less than 100. you are doing a lot of work to fix your pool, so don't stop when you have done 75% of the work. one more 50% drain should do it.
    another concern with having your CYA that high is the FC levels you maintain. remember that the pH test is invalid if your FC is about 10ppm. so if you are above that during regular loading you cant test and adjust pH. water is pretty cheap and you will save money in the long run by doing another drain and getting your CYA levels down. just chalk it up as punishment for following pool store recommendations now that you are on the TFP methods, you shouldn't have to worry about it again ever.
    and to answer your question, no, you will not bleach your liner. the whole CYA/FC relationship is based on oxidizing power of the free chlorine. that's why it goes up as CYA goes, up. a pool chlorinated at the target FC for CYA of 20 is the same as CYA of 100. in fact, even though you would be at FC of 12ppm with CYA of 100, its not as harsh as a pool with 0 CYA and 1ppm of FC, like a public pool. no worries at all
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    WalterE's Avatar
    Aug 2015
    Little Rock, AR
    37
    Following instructions from this forum, I have done two 1/2 drains and refill with city water. Would like some guidance as to what to do next in migration to BBB. I have locked up the pucks and the bags of shock and so far only putting gallons of bleach in the pool. It is taking about 1 gallon per day to maintain FC of 5.
    Prior to 1st Drain.. .
    FC 2.0
    CC 0.5
    PH 7.4
    TA 150
    CH 70
    Now here are my numbers after the 1st drain and re-fill
    CC 0.4
    PH 7.6
    TA 80
    CH 50
    Now here are my numbers after the 2nd drain and re-fill
    FC 2.0 right after refill
    FC 4.0 after 1 gallon of bleach
    CC 0
    PH 7.6
    TA 50
    CH 50
    CYA 80 coming down, but not quite there
    What to do next?. Can I live with this, maybe do another drain next spring? Any of the numbers bother you?
    Thanks for all your help. I'm still learning as you can tell.
    Aug 2015
    Montreal, Quebec, Canada
    36
    Hey Walter great job on getting you CYA down to a more manageable level.
    Are you seeing any algae. If not, I would stop draining and see if you can manage to the pool at that CYA level. Yes you will need a higher FC if you decide to SLAM but maintaining a proper FC in the balanced pool should be ok even at that CYA.
    Keep in mind that your should Target an FC of 9 (for CYA of 80) and never allow it to go below 6 to prevent any algae growth.
    Your TA and CH can be adjusted if needed.
    Do you have a heater or any other products that may indicate a need to increase your CH, if not keep it like it is (considering the warranty conditions for your products).
    I would see how stable my pH is at that TA and increase as needed.
    44000L oval above ground vinyl pool ---Taylor K-2006----
    Jacuzzi Saniclear 20 salt generator, Waterco XLRU50btu Heat Pump
    Jacuzzi L192 19" sand filter, Jacuzzi 1.5hp pump
    Pool School + Test Kits + PoolMath = Happy Times
    If in doubt SLAM - Shock Level And Maintain + Perform the Overnight FC Loss Test (OCLT)
    WalterE's Avatar
    Aug 2015
    Little Rock, AR
    37
    Thank you Paul, this helps a lot. No algae at this time. Pool is very clear. No heater.
    Montreal is on my list as the next vacation. Looking forward to seeing your beautiful city for the first time. Thinking about the train trip over to Halifax.
    wally
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    great job Walter! if you are going to close the pool, I would just stop with the CYA reductions. you will have to drain water for winterizing which will lower it further and you can make any more small changes next year when you open it. you have definitely set yourself up for success for next year, nice work! now just make sure you close your pool per the TFP guidelines so you can open up to clear water next year and avoid delays. keep your pool running until the water temp is 60 degrees
    Dan
    WalterE's Avatar
    Aug 2015
    Little Rock, AR
    37
    Thank you Danin. I don't close my pool for the winter. It is the highlight of the view from my house and I thought the cover distracted. What I'm thinking is to leave it like it is, keep the FC at 9 until next spring and practice TFP with BBB. At that time, do one more 1/2 drain and refill, which should take it to 40 for the swimming season
    Will that work?
    Also, What should I expect for the amount of Bleach to that will be required to maintain the target FC? I know it will vary depending on sunshine and other factors, but a ball park range. Especially over the winter where the usage should be significantly reduced.
    Thanks again for your help.
    Jul 2015
    Tempe, AZ
    194
    I've been managing the pool that came with our new house since July with a CYA of 80. In the worst part of the blaring AZ sunny days, I'd use a bit over a 1/2 gallon of 8.25% bleach to keep at or around the target of 9.
    It's tapered off as the temperatures have come down and the sun is starting to lean over more. A gallon jug now lasts 3 to 4 days. I was planning on doing the drain & refill to get the CYA in the 40 range at the end of our season, but might just wait until the spring if the bleach demand keeps decreasing.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Will that work?
    ok, gotcha Walter. in the winter with lower water temps your FC consumption is going to go down quite a bit. once you hit 60 degree water temp its going to go even lower. use pool math to determine the volume of bleach needed to replace 1ppm of FC, that's might be where you are going to end up at. during the peak of summer, probably 2-3ppm is typical.
    if you are not going to close the pool, I would do another water change and get your CYA down to 60-ish and then you wont have to worry about it later. but where you are at is manageable
    Dan
