Thread: Set Pentair 3 Way Valve - Fixed Position
    Sep 2015
    Wellington
    25
    Does anyone know if there is a way to set a Pentair 3 Way Valve in a fixed position? I have a valve that adjusts the flow between my waterfalls and the sunstep bubblers and I would like to insure that nobody moves the valve. (I 'm familiar with the stopping pins - but that seems to provide a range - not an exact stopping point.
    Thanks in advance for any replies
    Pentair EasyTouch 4, Three 12" Copper Bobe' Scuppers
    Pentiar ScreenLogic Interface w/iPhone App
    Pentair Intelliflo VS Pump, Intellichlor SWG
    Hayward Universal Colorlogic LEDs, Pentair Clean & Clear 200 Filter
    TF Test Kit
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Set Pentair 3 Way Valve - Fixed Position
    You can either tighten down the finger nut on the top of the valve handle, or you can remove it, and the handle so it can't be adjusted later. This if you don't have a valve actuator, if you do, just flip the switch to move the valve to the spot you want the valve at, then move the switch to the center position to disable the actuator.
    Factory Warranty Station for:
    Jun 2015
    Wildomar, California
    423
    Just remove the handle. Then someone will have to use pliers to change it's position.
    JoyfulNoise's Avatar
    May 2015
    13,177
    Just hang a sign on it that says- "If you adjust this valve I'll break your hand!" Works every time for me.
    Seriously, just remove the valve handle (but don't forget where you put it!)
    Matt
    Sep 2015
    Wellington
    25
    Thank you Pool Clown, OldPoolMan, and JoyfulNoise for your responses! Not sure why I did not think of the simplest, lowest cost solution of removing the handle. I guess I was too busy looking for locking mechanisms instead of sitting back and evaluating the problem Removing the handle will work perfectly.
    TF Test Kit
