Thread: Cyanuric acid and Chas' AG pool remodel
    Chas's Avatar
    Jun 2015
    Juneau Wisconsin
    37
    I posted a couple of questions in early June '15 re; CYA and iron control after I re-filled my AG pool with its new vinyl liner. Thanks to the great replies I received I've learned and observed some vital facts. I've been in the industry for way longer than I care to think about, yet have overlooked - out of ignorance and disbelief - the importance of CYA in the Tri-chlor tabs so many of us use. The past few years I've gone through way more chlorine and algaecide than was reasonable. This year, on a fresh water fill and after getting the iron from my well water handled, I tested daily and observed:
    1) My pool was absolutely trouble free, crystal clear and algae free all summer.
    2) I didn't add any algaecide after two weeks of removing the iron with no chlorine in the water.
    3) I added enough "stabilizer" (CYA) to bring the initial CYA count to approx. 10ppm. (Tested for with my new test kit from TFP)
    4) I went through 7 gallons of muriatic acid a little at a time in order to bring the TA from 410ppm (yes, you read that right) to the 120 ppm it is now.
    5) I ran the pool all season with 3" Tri-chlor tabs in my online feeder. No muss, no fuss, simple and troublefree.
    6) ALAS! Over the course of the past 2-1/2 months, the Tri-chlor pucks raised my CYA to 55ppm! From 10 in mid June to 55 on Aug. 31st! Gasp! OK, I'm a believer. My pool won't be trouble free for long using pucks!
    7) I went to hand feeding liquid. But, what a pain. I see with great interest a forum on ORP controllers and auto-feeding liquid - just like I did when I ran commercial pools back in the '80s. Kool! Next year's project.
    Thanks for a great website~! A closing pic of my remodeled pool -
    27' round 20,000 gallon AG pool, hard (vermiculite) bottom, center dished to water depth of 5'6" with main drain. All inground equipment; Sta-Rite 3/4hp Dura-Glas pump, Sta-Rite stainless steel "bullet" 100 sq. ft. cartridge filter, RayPak RP2100 LP gas heater, Sani-King chlorine erosion feeder. Custom return opposite the skimmer, Barracuda Alpha-1 suction side cleaner, 4 grandkids to stir up the water.
    38,271
    Re: Cyanuric acid and Chas' AG pool remodel
    Great to hear you had a fantastic pool season and that you now understand the chemistry a bit better.
    There are not many fans of ORP sensors here. They seem to be very temperamental in outdoor pools with higher CYA levels.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Knowledge is power!
    Nice set up you have!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Chas's Avatar
    Jun 2015
    Juneau Wisconsin
    37
    Thanks! I'll be studying on how to automate liquid chlorine monitoring and feeding - or - maybe go to salt chlorine generator? I sure would like to avoid a buildup of CYA and what that entails!
    Casey's Avatar
    SW PA
    10,428
    Go with the SWG. You'll get rid of the build up of CYA as soon as you stop using the pucks.
    The pool looks great!
