Results 1 to 11 of 11
Thread: Solar panels - Ecostar VS pump
    May 2008
    Marana AZ
    45
    I have 9 4x12 Heliocol solar panels in one single row on my flat roof about 16 foot off the ground. I have a Ecostar 3400 VS pump and 2" PVC lines to and from the panels. I would like to add 5 more panels in a new row to this system. Is the pump powerful enough to do this? How do I figure how many panels the pump will support? How do I figure out what speed to run the pump at?
    38,271
    Re: Solar panels - Ecostar VS pump
    Typically you want about 1 gpm for every 10 sqft of solar panels. You would likely have to run at a pretty high speed.
    This would end up being the largest system I have heard of on the forum.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I suspect in order to get maximum performance from your solar panels with the 14 4x12 panels you will need to run your pump at full speed or close to it, to know for sure you might consider purchasing a flow meter like the ones sold at TFTestkits TFTestkits.net By way of comparison I have a set of 11 4x12 Techno-Solis brand panels at a similar height to your panels with a 2 speed 1.5 HP Jandy Flo-Pro pump. When running on high with a clean DE filter I get just about 40 GPM of total flow, or 3.6 GPM per panel, where optimal flow is around 4.5 GPM.
    Ike
    May 2008
    Marana AZ
    45
    Sounds like if I have 14 panels I can run the pump at 3400 RPM and be pretty close. If I install a flow meter I adjust the RPMs to run at 70 GPM which is ideal.
    May 2008
    Marana AZ
    45
    Quote Originally Posted by Isaac-1 View Post
    Ike
    If I were to put a flow meter right after the VS pump would it help me determine what speed to run my pump at? For example. Throttle the pump back from full speed until the flow rate is desirable. Is this a good way to determine what speed to run the pump at? Could use this for all aspects of the pool ( solar, in floor cleaner, spa mode, spill over, etc).
    38,271
    Don't put it right after the pump. Use the FlowVis right after your filter where you need a check valve anyway.
    And yes it will give you an idea of the flow rate for all modes.
    May 2008
    Marana AZ
    45
    There is no room after the filter to put it. Why would it work better after the filter?
    38,271
    That is just the typical location for a check valve with solar. I suppose between the pump and filter should work the same to prevent backflow when the solar panels drain.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It depends on the type of filter setup you have and where the water from the solar panels would back flow to once the pump is off. If you would fill out your signature with your pool information like ours is it would be helpful in giving better advice.
    May 2008
    Marana AZ
    45
    Signature complete.
    13,000 gallon pool and spa, StoneScapes mini pebble midnight blue, Ecostar VS pump, Tristar VS pump for water fall, Hayward SwimClear C4030 filter, Hayward H400FDN heater, 9 4x12 Heliocol solar panels, paramount PV3 in floor cleaner, Omnilogic , T-15 salt cell, sense and dispense
    May 2008
    Marana AZ
    45
    Here are some photos of my equipment. Where would the best place to put a flow meter?
    If I start the pump at full speed and back the RPMs down until the flow rate starts to drop. Is that the most efficient RPM for the pump to run at?
    Attachment 42697
    Attachment 42698
    Attachment 42699
