Results 1 to 7 of 7
Thread: Is it ok to use 8.5% Walmart bleach in pool?
    Jul 2014
    Keller, TX
    8
    Split from Is sodium hydroxide in bleach normal/ok to use in pool? Zea3
    Wal Mart Bleach is now 8.25% Sodium hypochlorite. Still okay to use? (121oz jugs / just shy of a gal.)
    Is it okay to use sodium hpochlorite (liquid bleach) and calcium hypoclorite (Leslie's Power powder plus 73%) at the same time in the pool? I need to SLAM my pool and have about half of each. (4 jugs of bleach and 2 packs of power powder plus.)
    25,000 gal gunnite pool with spa, quartz finish. Chlorine Pool. Jandy Variable speed pump. Polaris 360 cleaner. Installed /2014.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Is it ok to use 8.5% Walmart bleach in pool?
    I use it every day.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    It's quite popular here, actually. Just be sure it's the plain stuff, not any splashless stuff.
    Jul 2014
    Keller, TX
    8
    I edited the original post. Is it okay to use it simultaneously with powder shock in the same pool when slamming?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Yes, but why?? Harder to manage and know how much FC to expect, unless working close with PoolMath.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Richard320's Avatar
    Jan 2010
    19,046
    Quote Originally Posted by dmp717200 View Post
    Yes. But don't dissolve the powder in the bleach.
    Predissolve the cal-hypo in a bucket of pool water and then treat it as bleach, pouring it in front of a return. Then add whatever bleach you need to add the same way.
    Jul 2014
    Keller, TX
    8
    Thanks. I was using pool math calculator and think I got it right.
