Thread: HTh test kit already--can I supplement with needed tests?
    Jul 2015
    Bridge City, TX
    79
    We just finished and filled our IG pool on Fri. we have the 6 way HTH test kit (bought before we found this site) But we know after reading we need the FAS/DPD. Should we just order the FAS/DPD test from TFTestkits to supplement what we already have? It looks like that is the only test we are missing. And maybe some extra CYA reagent? Thanks!
    24,000 gallon free form IG gunite pool w/8' round raised spa. 700 sq ft pea gravel decking. Tahoe blue pebble tech. Pentair 2HP Sulerflo pump. CCP 420 cartridge filter. Polaris 280. 320 inline chlorinator. Mastertemp 400,000 btu heater. Pentair LED light in pool and spa. Easy Touch automated system.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: HTh test kit already--can I supplement with needed tests?
    Sure, that will work fine.
    38,474
    You certainly need the FAS-DPD. But I am not sure if you can use Taylor CYA reagent in the HTH viewing tube. There might be a thread somewhere with that answer.
