Thread: Redoing plumbing, replacing valve?
    Aug 2015
    San Diego, CA
    16
    I need to redo plumbing to install a new pump. A 15 year old Compool 2 way valve is part of the plumbing before the pump intake and I am going to automate this valve. The valve works fine, but I am wondering if it may be a good idea to replace it at the same time or do you think I will continue to get good service from it?
    27,000 gal in ground white plaster pool. Sta-Rite System 3 DE filter, Sta-Rite heater and 2 HP pump. Solar heating on roof.
    Jun 2014
    15,153
    Re: Redoing plumbing, replacing valve?
    15 yrs is a long time for a valve. Really hard to know how much service life may be left on it. I'm personally not familiar with the brand. Maybe someone else will know. Technology is better today and some newer valves have longer or lifetime guarantees. Since you're re-doing the plumbing anyways, I would personally be inclined to replace the valve now while it's apart. If you chose not to, then hopefully the valve is attached by unions so that at the very least you can simply unscrew it later if needed. Good luck, and have a nice day.
    Qwaxalot's Avatar
    Jun 2012
    439
    I would replace the valve with a recent valve, if for no other reason than the older compool valves used screws to hold the top on that are an unusual thread size.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Jun 2015
    Wildomar, California
    423
    Compool valves are similar to Jandy valves. Switching to a Jandy valve and/or a Jandy valve actuator is a good choice.
    Aug 2015
    San Diego, CA
    16
    Suspected those answers. I will change it to a Jandy valve. Thanks.
