Results 1 to 7 of 7
Thread: Small liner cut repair suggestion
    I noticed today that have very small cut in my pool liner the size of a small child's fingernail clipping. It is above the waterline on a liner that is less than 2 years old. Given the age, I assume its not from dry rot and the kids somehow cut it it with a toy.
    Given the size is so small and that its about 2" from the top (lip) of the liner, I was considering patching it from the back of the liner. The reason is I still want a clean look above the water line. If this is not recommended, please advise and I'll follow the advice. It's almost in the center of the wall in the deep end (not a corner).
    Thanks
    27K Vinyl IG Pool
    18x36, Aquarite with Goldline T-15 SWG,
    Hayward 244T Sand Filter, 1.5 HP Hayward Super Pump w/ AO Smith B129 Motor
    Taylor 2006 Test Kit
    NW Louisiana
    Re: Small liner cut repair suggestion
    I would just patch it from the front. Try to match the pattern. Do you have extra material like from a step cutout?
    Support the site
    I do still have the original liner pattern I can use to match. I was just trying to keep it unnoticeable as it's still pretty new. Outside of the looks, is the hole going to affect the life expectancy of the liner?
    27K Vinyl IG Pool
    NW Louisiana
    A small patch with matching liner shouldn't be too noticeable. As long as the cut is not under stress, it shouldn't have a significant impact on the liner.
    Support the site
    It is hardly noticeable. I cut a piece trying not to utilize any more of the spare liner than necessary, so I have about .75" on one side of the cut and 2" on the other; Am I risking future problems by being too conservative with the spare liner? The cut looks as if it is not under stress; I attached pictures of the sample and actual cut below. I have some adhesive that I purchased at home depot; is it recommended that I ditch that for Boxer adhesive?
    Let me know if i need to adjust what I'm doing.
    27K Vinyl IG Pool
    NW Louisiana
    That's a pretty small cut. You only need a small round patch about 1.5" in diameter. As long as the glue is for patching vinyl liners, it should be fine.
    Support the site
    Yeah, it's really small; which was why I thought about patching from the back of the liner. I just want to make sure I was doing the right thing. I'll cut the patch down more and get it on there. The adhesive is for vinyl liners.
    27K Vinyl IG Pool
    NW Louisiana
