Results 1 to 7 of 7
Thread: Pool circulation - Please advise
    Sep 2014
    Ottawa, Ontario, Canada
    18
    I'd appreciate advise on the present circulation. Is it OK as is or would it be worthwhile to replace return jets so that I could improve the present circulation?
    Pictures below show the present circulation pattern; both return jets are at shallow end pointing up and across the pool.
    Attachment 42594
    At present, there is little circulation of water both at the shallow end (mainly at steps) and at the deep end (very little flow through main drain). These are the areas where algae tends to appear.
    I'd like to improve the circulation but the eyeballs in the Jacuzzi jets are frozen likely due to calcium deposits since 1968. Jets replacement would be rather expensive - $2600 ( a quote includes pool draining; drill through the pool shell from the inside to punch 4.5 holes through the wall; acid wash the pool)
    21K gal, IG plaster new 2010, 3/4 HP Super Pump with 2-speed AO Smith motor w/integrated 2Green timer, sand filter S-244T2, solar heating with HM-4000D controller, Dolphin M400 pool cleaner.
    Re: Pool circulation - Please advise
    Regular brushing should take care of the issues. Also, an automatic cleaner can be a big help.
    Support the site
    Jun 2015
    Wildomar, California
    423
    Why don't you replace the eyeballs? They're like $10 each?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    It might look a little weird but you could make 2 of these with less than 20 dollars in parts.. and trust me, it will move some water
    10 foot 1.5 inch pipe and cut pieces off it
    2 90 degree 1.5 inch fitting
    2 1.5 inch male thread on 1 end slip on other
    2 1.5 inch female thread on 1 end slip on other
    3/4 inch eyeballs threaded into the end
    Sep 2014
    18
    Quote Originally Posted by OldPoolMan View Post
    Many thanks for prompt reply. The return jet is shown below.
    Attachment 42602
    There are no spare parts for 1968 Jacuzzi jets. I have tried to remove the flange with the eyeball but was not successful. I passed a knife tip around the joint between the flange and the outside ring to remove any plaster or other deposits, removed the three screws, and finally tried to pull out the flange first with a finger and then with plumbers pliers inserted into the eyeball. The flange would not come out. I pulled hard but did not applied brute force to avoid breaking the eyeballs. Or, should I try to unscrew the flange with the eyeball?
    Sep 2014
    18
    Quote Originally Posted by cowboycasey View Post
    Dear cowboycasey,
    I have a follow up question.
    There are no spare parts for 1968 Jacuzzi jets; see picture. I have tried to remove the flange with the eyeball but was not successful. I passed a knife tip around the joint between the flange and the outside ring to remove any plaster or other deposits, removed the three screws, and finally tried to pull out the flange first with a finger and then with plumbers pliers inserted into the eyeball. The flange would not come out. I pulled hard but did not applied brute force to avoid breaking the eyeballs. Should I try to unscrew the flange with the eyeball?
    30,432
    I would call Jacuzzi in the AM and ask them how those old ones are installed
