Results 1 to 10 of 10
Thread: Need help, water leaking, other issues. Need to identify and fix
    beachinmoney's Avatar
    Jun 2013
    Buckeye, AZ
    159
    Hi, I'm home on my own due to husband being out on the road with work and I replaced my motor in my Hayward Northstar SP4010 pump with a 2 speed. The seal was replaced along with the impeller just to give you some background. My strainer lid was leaking water. I got a new o-ring and it still leaked a little but then about 2 weeks ago the union where the pipe goes into the top of the pump housing started leaking. I looked at it and the o-ring is fine, I guess they call that a gasket, no cracks in the nut or anything however the pipe that goes into the housing of the pump isn't threaded or anything and it's not glued in. I tried adding more lube and sealing it and it is still leaking badly. The strainer basket is melted so at some point it must have run dry. Now I need to know what to do to fix and if I can do on my own...
    Beachinmoney, live in AZ, Pool is inground approx. 14,500 gallons of water. I have a Pentair Intelliflo 2 VST pump. The pool was built in 2006 and Pentair Clean and Clear Plus Filter System. A&A in-ground cleaning system
    Jun 2015
    Wildomar, California
    423
    Re: Need help, water leaking, other issues. Need to identify and fix
    The pipe going into the top of your pump gas to be glued into the nut. Maybe that's why it leaks, or that gasket is crimped, no good, or has gunk on it.
    Jun 2013
    Buckeye, AZ
    159
    I don't understand, where does it need to be glued at? And the gasket, I have a few and I tried them all. So, all I need is some pvc glue?
    Jun 2014
    15,255
    Normally what we see is the PVC pipe with a "nut" on the end that screws onto the top of the pump. The nut (that spins or tightens) will be glued to that PVC pipe. It should be secure. There may also be a small black O-ring in that "nut" that screws onto the pump. Look it over closely for any defects. Maybe use a little magic lube on it - never petroleum jelly. From there, follow the PVC tubing to where it goes next - the filter or another union fitting perhaps? It may also have a "nut" or "union" fitting that has an O-ring in it. Those are just some ideas that may help you. If this doesn't make sense, maybe post a pic or two of what you have so we can see it better.
    Jun 2013
    Buckeye, AZ
    159
    Attachment 42603I think I got it. There is no screwing it in but I put a whole bunch of silicone on it to see if that seals it. I am going to let it sit for 12-24 hours and see if that works. I just didn't know if it was suppose to be glued in or what. Hope this works. Thank you!
    Jun 2014
    15,255
    Take a look at my pool's pump lines below in my signature (My pool). You'll see a couple pics of my pump station. There's the line that comes-up out of the ground (from the skimmer) and goes into the pump basket (suction side). Then you'll see the line that comes out of the back of the pump (on the top side) that goes to my filter. That's the "pressure" side. Either way, those knobs that twist (nut, union fitting, etc) are what actually screws onto the pump. But it's glued to the white PVC pipe. It should be glued to the pipe so that there is no chance it will pop-off later. Now if you just have just a tiny leak where it connects to the white pipe, then some silicone or epoxy may work if it cures good enough against the pipe. If the leak if from where the fitting screws onto the pump itself, it may be a small O-ring. Just wanted to give you that info. Either way, I hope you get it resolved. If not, post a pic or two tomorrow and we'll see what else we can do for you.
    Jun 2013
    Buckeye, AZ
    159
    I got some silicon and let it sit for 24 hours and it held for two days and now it's leaking again. Any suggestions?
    Jun 2014
    15,255
    Your best bet is to buy what is called a "nut" fitting or union fitting that is the right size to screw to your pump. The other end will be glued to the white PVC pipe. With a new fitting and perhaps a foot or two of new PVC pipe, you can be assured of a good strong fit.
    Jun 2013
    Buckeye, AZ
    159
    Re: Flood, need repair help... Need to identify and fix
    Removed. New thread started
    Jun 2013
    Buckeye, AZ
    159
    Removed and added to new thread.
