Thread: GAME Pool Light Review
    Jun 2015
    Houston, TX
    89
    All,
    I found a GAME brand pool light at my local pool store, it was a tad higher than what I think it should cost ($29.00), however I did buy it and it does put off a good amount of light. It has a magnet in the body for steel sided pools and a piece of powder coated steel for soft sided pools, the on/off Hi/Low remote does not appear to send the signal through more than 2' of water so I just turn it on and lower it into my pool.
    I will get some pictures of it tonight lite up, it operates off 3 AA batteries, and I will see how long it will live for. Oh yes its is only a white lite, no colors off the LED's
    Here is a link to the MFG
    http://www.game-group.com/products/p...emote-control/
    Thanks and have a great labor day!!!
    John
    AquaMaster Deluxe 8000 AGP, 5500 gallons, 12x18. Liquidator and Pool Rover JR.
    1st Pool so go easy on me I'm using a TF 100.
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Re: GAME Pool Light Review
    I have the same lights, I picked up a two pack on eBay.
    I've used one light about a half dozen times with no issues.
    I found the the one light I've used a little finicky when you tighten down the lens and required careful cross-tightening. When I first put it in the water I had a steady stream of bubbles coming from the light, a quick tighten and it's good so far.
    I discovered the same with the remote, it's IR and doesn't go thru water good at all.
    Here's one in my 18' X 48" Ultra Frame.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2015
    Houston, TX
    89
    Dom,
    That is how it looked last night, my pool is a tad smaller and I just tested it on the 12' side.
    I'm happy so far will see how long it last.
    John
