Results 1 to 8 of 8
Thread: Bought my first house with a pool
    Jun 2015
    Little Falls,NJ
    16
    My wife and I purchased our first home with a pool this past August. I knew maintaining a pool required work, but like anything new, there's so much that I need to learn. I've been reading up on some stuff especially since finding out this site.
    I've had problems initially with stubborn algae spots at the bottom. I've brushed, vaccumed and shocked the pool a couple of times but they just keep coming back every morning. I don't have the TFT-100 kit yet(just ordered), so I've been relying on the pool store and a basic Taylor pH and chlorine test. what I'm getting from the Taylor vs Pool Store test result in pH are so different.
    pH- 7.5(Taylor kit) vs. 8.5(Pool store test)
    FC- >5(Taylor) vs. 14ppm(Pool store test)
    TA- 160(Taylor) vs. 74(Pool store)
    CYA- 141(Pool store)
    Now that summer is ending, I figured it's a good time to remove a good amount of the water to lower CYA levels. Once I get the TFT-100 kit I can get a more consistent accurate results and properly close the pool.
    In-ground Clayton-Lambert Plaster built 1965?
    Capacity: 20,400 Filter: Sand
    Pump: Hayward Max-Flo II
    1 skimmer & 1 return - Floating chlorinator - TFT-100 Test Kit on the way...currently using Taylor pH, Chlorine and TA test and Pool store test.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Bought my first house with a pool
    Welcome to TFP!
    I'd suggest holding off on doing too much about the CYA. This test especially pool stores get wrong.
    Since you have the TF-100 on it's way, just keep adding liquid chlorine until it arrives, then post a set of results from that. We'll be better able to help you then.
    Jun 2015
    Little Falls,NJ
    16
    Thank you. Also I stopped using the Chlorine pucks as to not increase the CYA any higher just in case it is really high.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP!
    Congrats on the new pool! You are on the right track.
    EvanWilliams's Avatar
    Sep 2015
    Plano,Texas
    28
    Congrats on pool. Despite the work, they are awesome.
    Lot's of pool smart folks here, they will get you squared away.
    IG: 15000 Gal. Plaster. DE. 1992. Spa. Pump----(Will check brand and update). Heater. TF-100 Kit w Speedstir
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    And once you get it in balance, it shouldn't be more than a few minutes a day and vacuuming time once in a while.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    Little Falls,NJ
    16
    Thank you. I will definitely have a lot of questions and glad to join this community and get some pool knowledge.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Hi Romer,
    welcome to TFP and congrtulations on buying your first house.
    it sounds as if you have done your homework. You'll find the test kit and pool math to be invaluable.
    Good luck, and keep us posted.
    Divin Dave,
