Thread: Calcium level high
    Aug 2015
    Charlotte, NC
    12
    Calcium level high
    Took my first readings with TF-100 test kit. Read instructions and watched videos which were very helpful.
    pH- 7.5
    FC 4ppm
    CC 1.5
    CYA 60 ppm
    TA 70
    salt 3600
    Calcium hardness 475
    Calcium was pretty high but I am not noticing any significant scaling. Should I do anything about this or let it ride? If I need to do something how would I correct it? Do I just drain pool some and then add water to dilute it? Thanks!
    Built 11/2009; 16x25 IG free form with raised spa and spillover; 10,500 gal; gunite color quartz plaster finish; flagstone coping; travertine deck; Hayward NorthStar 2.5HP pump; U.S. motors 2HP motor; Hayward 525sf Swimclear cartridge filter; Autopilot salt chlorine generator; Autopilot pool chemistry controller; Polaris 3900 sport pool cleaner; Polaris PB4-60 pool cleaner motor(booster pump); Hayward 400K BTU heater, TF-100 test kit
    JoyfulNoise's Avatar
    May 2015
    13,189
    Re: Calcium level high
    Quote Originally Posted by MCarr View Post
    pH- 7.5
    FC 4ppm
    CC 1.5
    CYA 60 ppm
    TA 70
    salt 3600
    Your CSI based on those numbers is -0.17. You are not in danger of scaling. Your CH could go as high as 725ppm and you'd still be near 0 CSI. The only way to lower calcium hardness is to drain and replace pool water with a low CH source.
    If you're concerned about calcium, what is the CH of your fill water? That will tell you a lot about where you can expect your CH to go in the future.
    The more alarming number I see is your CC's are 1.5ppm. That's a bit elevated and is indicative of organics being oxidized by chlorine. That number should typically be 0.5ppm or less.
    Matt
    Aug 2015
    Charlotte, NC
    12
    Thanks, I appreciate the help!
