Thread: Chlorine-Free Sun Shock Water Purifier
    Aug 2015
    Grandy, NC
    135
    Really? Does this work? Says up to 35,000 gallons. Anyone have any experience? Chem Geek - anything? Or sounds too good to be true - probably is?
    Karen
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Chlorine-Free Sun Shock Water Purifier
    Just another copper ionizer. Stay away.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Straight from their website under the Product Description tab.
    Note: While Chemical-Free Sun Shock is extremely effective in killing algae and keeping your pool crystal clear, we recommend using a small (2 to 3 parts per million) of sanitizer to keep your pool microbe-free.
    2-3 ppm FC is pretty typical daily consumption for a pool without this miracle device. So where's the savings?
    They mentioned that the unit attracts "Calcium" I am on a water well, and I do have a water softener (house), but would not even try to fill my pool with softened water.
    Does this unit attract calcium like they state it will..??
    Because this is a hassle (see photo) glass beading.
    I also have a "Nature2 Express Mineral Cartridge" which seems to be a gimmick, should I abandon the Nature2 Express Mineral Cartridge if I use a "Sun Shock"
    22K gal Plaster, 3M color, (4) Sta-Rite Max-E-Pro pumps (P6E6G-208L), Sta-Rite System 3 Filter (Sm8-500),
    Pentair Intellitouch System I9 + 3,Pentair Intellitouch System I10X Expansion center, Intellitouch Spa remote.
    Helicoil Solar Heating, Sta-Rite SR400 (Propane) Heater
    (3) PG2000 Illuminators, Pentair 320 Chlorine Feeder, Zodiac Nature2,
    Pool Shark (GW7700), All Jandy Neverlube valves (with Actuators), Jandy Check Valves.
    Sam Light Spectrum Amerilite (color changing w/color swim) SaL (color changing w/color swim,also)
    Pentair Auto Fill ... 100% real Rock all Hand picked, no concrete formed rocks, or slab
    30,419
    I would abandon Nature2 and then not even consider this product. TFP teaches simplicity.
    Don't add things to your pool you don't need and, most always, don't work, either.
