Results 1 to 8 of 8
Thread: storing pool supplies in Phoenix
    Jan 2015
    Phoenix, AZ
    638
    We're trying to decide on a 5' x 2' Rubbermaid shed for pool supplies or a 4' x 5' or so Resin Suncast shed if we feel we can make it work on the side of our house. the 4' x 5's are starting at $600 and the 5' x 2' is $200 on sale, although, I don't want $ to be the only factor here. Ideally, I'd like to hang our vac hose on the side of the east side of our house, but I wonder about the sun hitting it in the morning til noon. How quickly would it break down? Phx sun and plastic don't mix. I"m thinking it's better in the shed. I'm not sure if they make hooks that can be placed inside those plastic sheds. Does anyone know if that's possible and/or how/where do you hang your hose (especially if you're in Phoenix/Tucson)? I'm thinking in a 5 x 2 it might be tight, but I could prob fit our salt, DE, muratic acid, 3 umbrellas, and hose. we also have some pool toys that we'd like to try to get in there if possible. ideas or photos for the smaller sheds and where you keep your supplies would be greatly appreciated! thx!
    40' x 12' IG shotcrete (3 1/2' 5, 4'), Hayward variable spd pumpSP3400VSP, Paramount PV3 in-floor, venturi skimmer, 14,400 glns, Hayward Turbo salt cell T Cell-15, UV, Hayward DE filter, model DE4820, 2 Hayward Color Logic 320 LED color lights, Hayward P4 w puck. 2" line to in-floor valve (46'), deck mount canister parascoping fountain, leaf canister, Marbella, pebble. new build 6-24-15
    Jul 2015
    Kentucky
    1,125
    Re: storing pool supplies in Phoenix
    Hello. I can't answer the questions on the shed sizes because I have a garage.
    I'm sure they do make things specific for hanging items in the plastic sheds, but I'm thinking you could probably use something like the Command Strips to hang the hoses from. You might have to put a string or rope around the hose to hang it by, but those things are really sturdy. I'm not sure if the heat will cause them to come lose, but it might be worth a shot. I'd think the command strips would stay better than one of those suction cup type things would?
    Also on the umbrellas if they have metal on them you might not want to store them with the MA or CL because it might interact with the metal. I'm not sure if there are any issues with the salt and DE being stored with the MA, but I do know you can't store MA and chlorine together because it can blow up. Hopefully someone will come along and let you know on that for sure, but it might be advisable just to get a separate plastic tote and store the MA by itself so you don't have to worry about any possible interactions. I hope this helps. Have a nice night.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Jan 2015
    Phoenix, AZ
    638
    crackerjack4u, wow, i never would've thought about MA interacting with the metal on the umbrellas with the MA in the bottle but i guess the MA and chorine r in bottles and r not meant to be kept together. i guess it's if some spilled on the outside? i'll look forward to other posts. thx much!!
    Jul 2015
    Kentucky
    1,125
    You're very welcome. It has to do with the fumes and the gas they put off. The chlorine will also do it to the metal because of the gas it puts off so the 2 gasing together is Not a good thing. My motto is safety first, Always.
    Here's a couple of interesting links:
    http://www.troublefreepool.com/threa...tored-together
    http://www.troublefreepool.com/threa...he-garage-RUST
    http://www.troublefreepool.com/threa...ring-Chemicals
    Have a nice night.
    Jan 2015
    Tempe, AZ
    15
    I live in Tempe, and I have this product which I purchased locally at Costco, but which is also available online:
    Lifetime Horizontal Shed
    I have only had this for about 6 months now, but it is doing just great so far. I was also concerned about Phoenix sun, and I have several friends that had the Rubbermaid sheds, and they quickly warped and fell apart. So I knew when I got mine, I didn't want a Rubbermaid.
    So if you weren't interested in the shed I linked, and you want to stick with the two you mentioned, IMO, I would only consider the Suncast one of your two choices. (FYI, SUncast also makes other size sheds, and you can find them online)
    As for hooks, I would just use any old Hook that had screw holes on it, and I would use some large diameter, but short screws, something like #10 or #12 by 3/4" long screws, and just screw the hooks to the plastic. You actually assemble the sheds with similar screws actually, so why not also some hooks? Just be super careful and don't over torque the screws. Using a hand screw driver would be safest.
    Additionally, both Lifetime and Suncast have hook/shelves/brackets that can be purchased, you can find them online. I have not used these, I just found them on a search.
    40,000 Gallons- "Lazy L"; IG-Fiberglass; Pentair Clean and Clear+ 520; Circupool VJ3 VS Pump (2.4 SFHP); Circupool SJ-45 SWG
    Jan 2014
    Buckeye AZ
    807
    I have my bleach indoors in a small cabinet by the sliding glass door.
    I have my MA out next to the pump. We built a wood shed around our equipment (no floor, no posts, just framing and roof).
    Sometimes, due to sloth when unpacking the car, a bleach and a MA will end up about 10 feet apart in the garage for a few weeks. Haven't noticed anything corroding yet.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Mar 2015
    Sugar Land , TX
    424
    +1 for Costco Lifetime shed. I store hose and MA and other various pool outdoor items. Keep the bleach in garage.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Jan 2014
    Buckeye AZ
    807
    Considering I use the bleach every night, I can't imagine taking it to and from the garage every night. I guess it depends on your arrangement. Our little cabinet fits 2 or 3 gallons, and it's literally 4 seconds to grab the gallon and be at the pool side with the measuring cup.
