Thread: 50W Transformer with Single Intellibrite?
    Oct 2014
    San Marcos, Ca
    62
    I am replacing a 120V halogen light with a 12v Intellibrite light. The manual says you can connect 3 pool lights and a spa light to one 300W transformer. I only have one light in my pool so can I use a 50W Transformer?
    12,000 gallon IG plaster
    Cartridge filter
    Intellifo VS
    EasyTouch Controller
    Pentair SWG
    Dec 2014
    Riverside California
    482
    Re: 50W Transformer with Single Intellibrite?
    According to the Pentair brochure for the Intellibrite 5g, the color changing light is 26 Watts. Therefore your 50 Watt transformer would work for ONE color changing light only. If your Intellibrite is the white version only, then it will draw 55 Watts and you cannot use a 50 Watt transformer.
    http://www.pentairpool.com/pdfs/intellibriteDS.pdf
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
