Thread: salt level low
    Jul 2015
    Surprise Arizona
    1
    salt level low
    I changed the times that I run the pump due to less electricity cost and now my salt level, which was at 2900 is now 2400. If I run pump during the day, will the salt level adjust itself. If not, what do I do to get it back to where it should be?
    Jun 2014
    Roseville, CA
    343
    Re: salt level low
    That should not have changed.
    What is your PH? Sometimes a falling salt level is a signal that your SWG is not operating efficiently and needs cleaning. A high PH can accelerate clogging in your cell.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    JoyfulNoise's Avatar
    May 2015
    13,171
    salt level low
    What are your water temperatures like during the day and overnight, especially when the cell is running?
    If your salt level is on the low end and the water temp drops, SWGs that are not temperature compensated will show a salt level that drops with temperature. It's not actually the salt that is changing, it's the conductivity of the water that is changing. Warmer water conducts electricity better than colder water and the SWG will register that as a drop in salinity.
    Do you have a salt test kit (K-1766)? You need to check your salt level and see if adding salt to make the SWG happy is possible. If your true salt level is normal or high and the cell is saying its low, then the cell either needs to be cleaned or it is dying.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: salt level low
    Welcome to TFP?
    The two are unrelated. How are you testing salt? Most salt tests are +/-400 ppm and are really only intended to keep you in the ballpark. Is your SWG happy? Making chlorine? Giving a low salt error? Have you checked for scale on the plates? What is the ideal range for your swg?
    If the SWG is happy and making chlorine then be happy.
    If it is giving low salt error and the plates are clean then add salt up to the low end of the recommended range for your swg or around 3000 ppm. Most SWGs have recommended range of 2800-4500 ppm.
    30,401
    Re: salt level low
    Pump run time and salt level are not related. Do you have a pool service or are you managing your pool?
    Jul 2014
    Hope Mills, NC
    566
    Re: salt level low
    The display on the SWG screen is an average over the past "X" hhours. Maybe that average changes with run time, I dont know.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
