Thread: Wanting to convert back to chlorine ..
    Sep 2015
    Brenham Texas
    3
    I'm new on forum - I'm here because we want to convert back to chlorine - from Bacquil(so?). I'll check to see if there is a previous thread on this but wanted to introduce myself...
    We have a 15,000 gallon above ground pool.
    ​JAKS
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Wanting to convert back to chlorine ..
    There is actually a whole section of pool school dedicated to it! Enjoy and welcome!!
    Here you go: Pool School - Convert Your Baqua Pool to Chlorine
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Welcome to TFP!!
    We can help you with that conversion. Grab a pint of Blue Bell and settle back to read this article from Pool School - Convert Your Baqua Pool to Chlorine
    Support the site
    Sep 2015
    Brenham Texas
    3
    Thanks - I have read the article - I've ordered a test kit ...not sure how the math works on getting the correct amount of chlorine/bleach to start? I'm "Poolmath" challenged...
    Other sites recommend a non chlorine shock before starting adding chlorine?
    Can the pool be used during the conversion process?
    ​JAKS
    May 2014
    Franklin, NC
    9,179
    Quote Originally Posted by Jaks View Post
    How many gallons in your pool?
    This is where many folks get into trouble, trying to "blend" advice from multiple sites. If you are going to follow our advice, stick to chlorine.
    That would be no. Once you pour the chlorine in you will understand why.
    Support the site
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Echoing what Tim said, it's best to avoid commingling advice from different sites/sources - you are likely to run into conflicts which will stall your progress. I would recommend following the process outlined in the Pool School - Convert Your Baqua Pool to Chlorine article.
