Results 1 to 8 of 8
Thread: CH Level
    Jul 2015
    CA
    19
    CH Level
    Is the TF-100 CH test accurate when the CH is at a low level? The instruction says, I think, that when CH is low, divide the number in half - is this right? I thought that my water was soft - I've tested it with 2 local Leslie's and the results were both on the low side, like 180, but the TF-100 is twice of that. Is 1/2 of TF-100's number right?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: CH Level
    Believe your reading.
    Testing and Balancing Your Water mentions using a larger sample size when testing low levels. That's all. Make sure you use the correct multiplier for the sample size you're testing.
    Jul 2015
    CA
    19
    Re: CH Level
    Yeah, I tested it again with the 25 ml water test and it came back at 250, vs 325 before. I didn't think 250 was that low where it could cause a difference this big.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: CH Level
    There are more detailed testing instructions here, Extended Test Kit Directions, that might help.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: CH Level
    I don't know what the divide in half thing you've mentioned is but the standard and extended test specs for the TF-100 CH test are:
    25ml sample
    - 20 drops of R-0010
    - 5 drops of R-0111L
    - count R-0012 drops till color change
    - number of R-0012 drops times 10 equals CH reading
    10ml sample
    - 10 drops of R-0010
    - 3 drops of R-0111L
    - number of R-0012 drops times 25 equals CH reading
    I think the 10ml test is primarily to save on reagents so you can make the reagents last the season.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jul 2015
    CA
    19
    Re: CH Level
    Quote Originally Posted by pooldv View Post
    Yes. Thanks you.
    Jul 2015
    CA
    19
    Re: CH Level
    Quote Originally Posted by gtemkin View Post
    25ml sample
    10ml sample
    I am not sure what I got that impression from either. Probably from the comparison between my and Leslie's.
    I did the 2 tests 10 ml and 25 ml and got 325 and 250 - you would think that the results should've been closer. I'm trying to determine if I could use Cal-Hypo to help jacking up the CH level, but the results from the 2 tests are so different.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: CH Level
    It is a test I've had problems with. I've found that using a Speedstir definitely helps and as you approach the color change point, you have to slow down with your drops 'cause the color takes a second or two to change and if you add drops too quickly, you may add a drop or two to your count that you didn't need to. It's real easy for example to add 2 drops on the 10ml sample that may not be necessary, which if not added would have put your 10ml test at 275; pretty close to on par with the 250 of the 25ml test.
