Thread: LoopLoc II Cover Install
    I have a 38' x 14' fiberglass, Leisure Moroccan pool I've purchased the LoopLoc cover and need to install same. Shape of pool is basically rectangle with a about a 15' "half moon" indentation on one side. Instructions call for laying out a a grid of line to support cover prior to installation, but, I've read in several places on the internet that you just center the cover, measure back 18" from cover edge, and sequentially install anchors..
    Anyone else installed one of these and have do/don'ts and/or lesson learned? Thanks in advance...
    N Virginia
    -Leisure Moroccan 38' Fiberglass
    -19,800 Gallons
    -Pentair EasyTouch 4 w/IC40 Chlorinator,VS3050 Pump, Clean&Clear Plus 320 Cartridge Filter,Prowler 720 Robot Cleaner
    -1 Skimmer/ 3 Returns/2 Drains/2" Piping
    -3 Fiberstar Pal Treo LED lights/Wirtran
    -TF100 TestKit
    Re: LoopLoc II Cover Install
    Bump....
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    I don't know how you'd center the cover without the grid of ropes. The cover will be incredibly heavy once it touches the water and that will pull the edges into the pool. It shouldn't take a half hour to string the ropes.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by JohnT View Post
    +1 Agreed, you need to run the grid of ropes to support the cover. Drive stakes into the nearest available ground around the pool to anchor the ropes. Also make sure the spring buckles are not fully tight to the cover so that you can adjust them when the anchors are installed.
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I would lay out a grid of ropes for determining the position of your anchors. You'll want to set them up as close as you can to the grid layout of your actual cover. This will help keep the cover square and eliminate problems with cover bulging and creasing due to out of position, out of square anchor locations. You can do this without the cover on, install the anchors 18" from the pool edge, then put the cover on once anchors are installed and ropes removed. Meticulous installation of the anchors will save you from problems later, such as having to reposition anchors and drilling more holes in your decking.
    Isolated Spa - 345 Gallons
    I fill the pool to the top of the coping stone when I am installing a new pool cover. The cover slides easily into position and buckets of water can easily keep the cover where you placed it.
    IGP/Spa, 44X21 Gunite Pool, 700SqFt, 30K Gallons
    Pentair Clean and Clear 420SqFt Cartridge Filter/Pentair IC40 SWCG/PCC2000
    Pentair 400K BTU Propane Heater
