Thread: Pressure dropping when we need to clean
    lovestoswim's Avatar
    May 2015
    Milford, Ohio
    102
    I am not sure our pump has ever worked properly. In order to get a reading on the gauge we have to have our pump on high. On the low setting the needle barely moves.
    After filter is cleaned high setting reads 12-14. As it gets dirty is drops to about 10. That's how we know we need to clean it.
    What do you think is causing this?
    Thank You in advance! Everyone here is so helpful
    24,000 gallon, 21x43 Oval Wilbur AGP installed June 2015. 10'X24' deck. 2hp Aqua Pro Cartridge Filter. Using TFP method.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Pressure dropping when we need to clean
    Dirty filters cause pressure to rise, not fall. Time for a new gauge I think.
    May 2015
    Milford, Ohio
    102
    We thought the same thing so we have actually replaced the gauge twice
    I should note: I noticed it after vacuuming yesterday. It was at 10 and then after vacuuming and cleaning the filter it went up to 12.
    Jun 2014
    15,211
    If needed, you might like to look at one of these gauges for only $11: TFTestkits.net. Glycerin-filled, a very good value.
    May 2015
    Milford, Ohio
    102
    Thank You Texas Splash! I am not sure if we need a new gauge or not. The company sent us a new one a while ago. So we have two and both do the same the thing. Our pool/pump is brand new. Purchased in May.
