Thread: Ta low?? 96 and Ph high 8.1 what to do first
    Aug 2015
    Arnhem/Netherlands
    109
    Hello my Ta is 96 low??? and Ph 8.1 to high.
    What to do first.
    Decrease the PH or increase de Ta.
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Ta low?? 96 and Ph high 8.1 what to do first
    Your Ta is most likely ok, but by reducing your PH with muriatic acid to low 7 range, you will, in turn reduce your Ta a bit as well.
    JoyfulNoise's Avatar
    May 2015
    13,244
    Edwin,
    Your sig only mentions a spa (250gal). Do you have only a spa or pool too?
    Matt
    Mar 2007
    San Rafael, CA USA
    12,082
    A TA of 96 ppm for a spa using bleach is way too high. Spas have more aeration, shallower depth, and hotter water temperature than pools so will outgas carbon dioxide faster. A higher TA has such outgassing occur even faster. The sticky on How do I use Chlorine in my Spa suggests 50 ppm for the TA level, but that is with 50 ppm Borates for additional pH buffering. Since you are unlikely to be able to get boric acid for the borates, you should try the lower TA but be careful to not have the pH get too high too quickly (i.e. you'll need to check it more frequently).
    Why do you think a TA of 96 ppm is too low? Where are you reading that? You cannot use "standard" industry advice. It's either wrong or incompatible with the advice we give that is based on actual science.
    Aug 2015
    Arnhem/Netherlands
    109
    Ok Chem geek.
    A delaer told me TA most between 80-120
    But how can i get lower the TA?? to 50 (the most chemicals are forbidden in the Netherlands)
    OK this the way to lower TA.
    The acid/aeration process to lower TA:
    1. Add acid to lower your PH to between 7.0 and 7.2 (this also lowers TA)
    2. Aerate until PH rises to around 7.6 (the only way to raise PH without also raising TA)
    3. Repeat steps 1 and 2 until you reach the desired TA
    Joyfulnoise,
    i have only a spa
    Factory is Caldera
    Above ground
    6 months old now.
