Thread: TFP ideal fc level vs test kit ideal fc level
    Sep 2015
    thailand
    12
    My saku ph &cl test kit model dv-3025 shows the ideal CL level (i am assuming they mean FC level) to be in the 0.6 - 1.5 range. Yet this forum says my FC level should start at minimum of 2 with a target of 3 given my low CYA level.
    Mother in law thinks I'm trying to poison her grandkids. As their swimsuits smell like bleach at FC 3.
    Can an experienced forum member assure me that I'm not poisoning her grandkids?
    Last edited by rangerwildtrak; 09-06-2015 at 04:19 AM. Reason: tried to upload a photo but couldn't
    15' 48" Intex 4400 gallon AG vinyl pool with small stock Krystal Clear 638R filter pump that comes with the pool. Pool outside yet is covered with a 19' square blue tent (no direct sunlight). Saku ph & cl test kit model: dv-3025. NE Thailand.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: TFP ideal fc level vs test kit ideal fc level
    What is your CYA level?
    That tester is most likely giving TC which is a combination of FC and CC But you don't know which is dominant. FC is a clean bleach smell CC bring a harsh smell. That is an over simplification but appropriate for this point in the conversation.
    You really need to find a tester that give FC and CC separately. And CYA test also.
    If you are running NO CYA then you need to be down where the testkit recommends. Our standards assume a CYA of at least 40. Even for indoor pools.
    You are not poisoning them but if your CYA is 0 then you are running closer to SLAM level. It is still safe to swim, just a little hard on suits and stuff like that.
    Now for the question list:
    How are you chlorinating the pool?
    What other stuff have you put in there?
    What testkit do you have?
    How does the water look?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Considering the EPA permits your drinking water to be 4ppm chlorine, I'd say you aren't poisoning anyone.
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Sep 2015
    thailand
    12
    Quote Originally Posted by pabeader View Post
    Thanks Pabeater.I actually responded a few days earlier with an extensive reply as the insight of your post was very helpful. But I hit the wrong button and lost it. But at this point the pool is clear running smoothly. Thanks again.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Glad to hear about the happy pool!
    Any time. That's what we're here for!
