Results 1 to 7 of 7
Thread: ok so its been a couple weeks now, how am doing...
    Jun 2015
    Mesa, AZ
    16
    so its been a couple weeks now and water looks great. started off with a new AGP and started TFPC right away. (also my first pool) so here are my current levels. honestly ive only been testing the FC and adding chlorine accordingly, and doing PH every 3rd day but its not really moving much. but with it being a few weeks now and AZ temps are starting to drop below the daily 110* mark i figured id do a whole test of all the levels again. id appreciate any feedback...thx
    FC - 3.5
    CC - .5
    PH - 7.9
    TA - 130
    CH - 40
    CYA - 80
    these were numbers tested around 9pm like when i normally test before doing any adjustments and ive been using pool math which is awesome.
    22' X 52" Intex Ultra Frame AGP 10,400 gallons
    Intex 3,000 GPH sand filter & Hayward thru-wall skimmer
    Taylor K-2006 test kit
    Aug 2014
    Northern IL
    4,615
    Re: ok so its been a couple weeks now, how am doing...
    What did you add? Your FC is really quite low for your CYA and your pH is high.
    Jun 2015
    Mesa, AZ
    16
    Quote Originally Posted by MarianParoo View Post
    i just add LC, have to add little over a quart daily according to pool math.
    Aug 2014
    Northern IL
    4,615
    With a CYA of 80, you need to target your FC to hit 9ppm, NEVER falling below 6ppm. See: Pool School - Chlorine / CYA Chart
    Also, I would lower that pH. Did you select "troublefreepool" at the bottom of PoolMath?
    Jun 2015
    Mesa, AZ
    16
    thank you! glad i posted this (debated if i should or not) for some reason i was reading the minimum FC on the chart and typing that in for my goal on the calculator . also never noticed the Suggested Goal Levels with drop downs at the bottom of the page...thx again
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,945
    FC of 3.5 is too low with a CYA of 80. Your target is 9 with a minimum level of 6. Take a look at the Chlorine/CYA Chart.
    I find your CH reading of 40 hard to believe. Are you sure of your test readings?
    chiefwej
    Aug 2014
    Northern IL
    4,615
    Please don't hesitate to ask questions again!
