Results 1 to 7 of 7
Thread: How fast can a heat exchanger corrode?
    Sep 2015
    Newington, CT
    1
    I have had my pool for 3 months. It has been leaking for probably about a month, and when the pool company came to fix it they told me the heat exchanger was corroded and that it wasn't covered under warranty because it was from low pH. I have checked my pH almost every week and it has only once been low, probably for not more than a week. He is charging me $500 for a new heater and I don't believe that I should have to pay for this when I paid $3000 for the heater only a few months ago. Can anyone tell me if this is reasonable or not?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: How fast can a heat exchanger corrode?
    Hi Kedelson,
    welcome to TFP.
    Man, manufacturers and pool companies will use about any excuse not to honor their warranty. I have heard of a few occasions similar to yours, where the manufacturer want a record of all the testing since forever to even consider honoring warranty.
    Im afraid I dont know how long it would take a chemistry problem to corrode the pipes. Maybe someone else will come along who has more knowledge about that than I do.
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Maintain your chemicals correctly Apparently, it can happen quick. Are you by chance using pucks to chlorinate? Do you set them in the skimmer?
    Nov 2011
    Moberly,MO
    1,010
    From past experience it does not take long. And with newer copper exchangers even less.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    JoyfulNoise's Avatar
    May 2015
    13,176
    Quote Originally Posted by Divin Dave View Post
    This is so true. And if you do show them a sheet of all your own measurements, they won't accept them. They will tell you that they only accept records from pool store testing or from a licensed pool service company.
    Matt
    Richie Rich's Avatar
    Jul 2015
    Riverside, CA or Lake Havasu, AZ
    69
    dang man...crazy how fast that type of thing can happen
    Pool Build Finished 08/21/15
    17x30 IG Gunite pool/7' spa with gray plaster filled with city water
    Pentair VS 3 hp (pool guy set to run from 0600-1400)
    Pentair 420
    Pentair 400k heater
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Yes goes very fast.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
