Thread: FAS/DPD test kit THAILAND
    Sep 2015
    thailand
    12
    Anyone living in Thailand that knows how to aquire a proper test kit please enlighten me. Recently made an impulse pool purchase and had no idea that there was so much to maintaining one. It smells as though i have to shock the pool but do not have a fas/dpd test kit (nor am able to test CC). So as i understand it I'll be blind without it.
    15' 48" Intex 4400 gallon AG vinyl pool with small stock Krystal Clear 638R filter pump that comes with the pool. Pool outside yet is covered with a 19' square blue tent (no direct sunlight). Saku ph & cl test kit model: dv-3025. NE Thailand.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: FAS/DPD test kit THAILAND
    While not as accurate, if you have a DPD chlorine test kit that has a comparator with shades of pink/red, you can dilute a water sample to be able to read higher chlorine levels. You'll still need to find a kit that has a Cyanuric Acid (CYA) test. This doesn't replace getting a better kit bit may let you get by for now.
    Sep 2015
    thailand
    12
    Ok thanks
