Results 1 to 14 of 14
Thread: Toxic Waste Pool
    Toxic Waste Pool
    Hello, This is my first post to this forum. I have been using bleach for the last 3 years after finding this web site and haven't seen any algae in all this time, so I know that this system works. However, most everyone else I know that has a pool still uses trichlor as their main source of free chlorine. I just tested my son in laws pool as we are watching the dogs while they are out of town and I figured we would swim in it tomorrow. I use taylor chemicals for all my testing. I took a sample and went home to test it. The results have shocked me( no pun intended). I had to retest my own pool to make sure that there was nothing wrong with my test chemicals. FC .5 ppm, TA untestable as the 5 drops of indicator that is supposed to turn the water green actually turns red immediately, without adding any sulfuric acid. PH test is so low off scale it is also unreadable. the color is a pale yellow. CYA is 60. The pool is inground vinyl lined, However the water is clear as a bell. I will NOT be swimming in it tomorrow. None of this makes much sense, am I going crazy. Has anyone seen these kind of test numbers.
    Jul 2015
    Kentucky
    1,125
    Re: Toxic Waste Pool
    Hello thatguy, and Welcome to TFP ,
    Wow, just wow, on the test results. I'm surprised they're not having all kinds of skin, eye, itching, burning issues etc.
    I've seen some pretty funky numbers, actually had some of mine own at one time, until TFP set me straight.
    I agree swimming in that pool, with those levels, wouldn't be my idea of fun either. (Nor would I want my family in there until the levels are straightened out).
    It sounds like it could be time to have a chat with your son in law about the severity of the levels in the pool, and how important it is to Maintain adequate numbers to not only prevent algae, equip damage, but also have a safe swimming environment level wise that isn't possibly also allowing bacteria to grow in there. Tell him about the TFP method, and send him our direction, and well be glad to help you, help him, to get it figured out.
    You'd be surprised the amount of people who just don't know what they need to do to adequately maintain/sanitize their pool. They just blindly add this or that and as long as the pool looks clear then the pool is fine. But a clear pool does Not always mean a clean pool. I know this because that use to be ME, but not any more.
    He may not be having problems Yet, but I can almost bet that day is fast approaching.
    So yeah, please do send him our way if possible so we can help him, help his pool, and until then you might want to put up a No Swimming sign.
    Again welcome to TFP, and Have a Wonderful Night.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    the PH and TA have crashed and you have an acidic pool... it is from using Trichlor as it drops both... it is speeding the process of eating any metal parts the water touches and is probably not safe to swim in.. they are probably complaining of itchy skin, burning eye's...
    baking soda and pool math are you best friends right now...
    JoyfulNoise's Avatar
    May 2015
    13,193
    The low FC could be from transporting the water sample. You don't want to leave a water sample lying around for more than 30 min or so as the FC starts to drop.
    As for TA, I'm not surprised by the results because he is using trichlor which is very acidic and will lower TA substantially in a vinyl lined pool. If he's using trichlor he should also be testing TA and adding baking soda as needed.
    With 0 TA his pH could be as low as 4.5 maybe even lower than that. If he has heater on that pool then acidic water is going to corrode the heck out of the heat-exchanger. I would definitely NOT swim in that pool or else you'll be in for a good case of stinging eyes.
    Matt
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    some soda ash would be good wouldnt it, to raise both pH and TA?
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    JoyfulNoise hit the nail on the head about the TA and the pH. With 0 TA, the test solition turns red immediately which means the pH is about 4.5
    The pucks are the culprit for sure.
    I would suggest to get the FC up first, and then bring up the TA and the pH as quicly as is reasonable
    Divin Dave,
    May 2015
    13,193
    Quote Originally Posted by poolnoob.ca View Post
    I would use borax to raise the pH and baking soda to bring up the TA. Soda ash (sodium carbonate) would work as well but I'd prefer to control the levels independently. And it's typically easier and less expensive to find borax/baking soda as opposed to soda ash. The pool stores do sell soda ash but at a huge markup.
    Matt
    Aug 2014
    Northern IL
    4,615
    Getting pH up would be my first goal. FC next. With a pH so low, I would see of they would agree on your helping out until they get home.
    Mar 2007
    San Rafael, CA USA
    12,082
    This is why we always say that just because water is clear that does not mean the pool water is safe or in good shape. In this case, the pool's pH has crashed from Trichlor's acidity exhausting the TA. Low pH will corrode metal and degrade the vinyl liner. Eyes could sting if opened underwater for too long.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    When you start adjusting this for him, it is possible that it might get a little cloudy, but it should pass rather quickly.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    30,414
    Adjust at your own risk.....no good deed goes unpunished.
    Donldson's Avatar
    NW Ohio
    2,892
    Adjust at your own risk.....no good deed goes unpunished.ale:ale:
    I agree. Let him know what you found but don't mess with anything. If the acidic water has done any damage then you are going to get blamed for that damage by meddling with his perfectly clear pool...
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2015
    13,193
    Personally speaking, I would not touch his pool without his express permission and in full agreement with him about the treatment. I'm a big believer in "you don't touch another man's pool. "
    Matt
    Jul 2015
    Kentucky
    1,125
    I agree, Don't do it.
    But as I mentioned above, send him our way, and we'll happily teach him to adjust his Own pool, and you can be the in town supervisor.
