Thread: New pool build in Prosper, TX - looking for advice on these quotes
    Jul 2015
    Prosper, TX
    2
    I got some pool company recommendations from my home builder and narrowed the list down to 3 companies that are relatively close to the new house and have built a lot of pools in the area. Please jump in with any comments/criticisms/advice/experiences/etc.
    Gold Medal pools (my home builder's top pick), Southernwind pools (based on positive things I read here), and Riverbend-Sandler pools (based on their popularity and several people we know that have one of their pools). I explained to each pool builder that I wanted a nice free form pool, spa, and water feature(s) in a "play pool" depth. I told them that I wanted to keep the entire back yard under $100K, including all of the pool stuff and landscaping and about 250' of wrought iron fencing.
    I know that these quotes won't be exact comparisons since I'm going on the information provided to me, but if I'm missing some information that is required to make a comparison please ask me and I'll do my best to find out the relevant information. Hopefully some of the more experienced folks out there can give me some advice and opinions.
    Gold Medal pools quote
    80 linear feet perimeter pool
    414 sq ft pool surface area
    12,938 gallons
    3.5'x5'x4' depth
    Steel reinforcement #3 steel @ 12" O.C. (tied together with pool steel)
    6" frost proof tile
    Interior finish Stonescapes
    Coping - Tennessee flagstone
    Steps/benches included
    In-pool table with stone cap
    6' waterfall feature with Arkansas boulder coping
    30' of Arkansas boulder coping
    731 sq ft of decking plus patio (approx 1493 sq ft total) khaki stone textured concrete decking
    Lifetime structural warranty on gunite
    Minimum 10" thick walls and floors
    2 independent skimmers
    4 drains
    2 DBL main drain with hydrostatic relief valve (independent)
    5 returns
    1/2" fill line
    Upsized 2.5" suction lines
    Overflow
    Filter - Hayward DE 60 sq ft
    Pump - Hayward TriStar 2HP
    Cleaner - Polaris 280
    Chlorinator Rainbow 320 w/O3 Ozone system
    Heater - Hayward 400,000 BTU
    Pool lights (2) Savi SOL H LED
    23 linear feet spa perimeter
    5 or 6 Power Therapy jets
    Blower 1.5HP or 2.0HP
    18" elevation
    3' boulder spillway
    Spa fountain
    Spa light (1) Savi Mini Melody LED
    E Command wireless controller with freezeguard
    $73,576
    Southernwind pools quote
    Riverbend-Sandler pools quote
    109 linear feet perimeter pool
    665 sq ft pool surface area
    22,982 gallons
    3.5'x5'x4' depth
    Steel reinforcement 1/2" steel @ 8" O.C. & 4" alternates in stress points
    Beam to have FIVE 1/2" steel bars in continuous pool beam
    6" ceramic tile 140' of coping
    Interior finish River Sand
    Coping - Oklahoma stone 14"
    3 Steps/15 sq ft included
    3 Benches/19 sq ft included
    24" elevated planet with (3) 24" sheer descent waterfalls
    and (2) 22" diameter 30" tall OK stone columns at ends
    771 sq ft of decking plus patio (approx 1492 sq ft total) deco seal tan textured concrete decking
    Gunite is 18"x10" beam with keyed notch for deck
    Minimum 8" thick walls and floors
    Coves a minimum of 10" to 12" thick
    2 safety main drains
    5 returns
    1/2" fill line
    2" suction lines
    1.5" return lines
    Latro Autofill
    Overflow
    Filter - Jandy DE 60 sq ft
    Pump - Jandy 2HP Variable Speed
    2HP ProFlo Booster pump
    Cleaner - In Floor system
    Chlorinator Rainbow 320 w/ Del Ozone Fusion system
    Heater - Jandy JXI400 400,000 BTU
    Pool lights (4) Jandy LED
    ? linear feet spa perimeter
    Arm rest, dual level benches
    8 Hydro Therapy jets
    2" suction lines
    1.5" return lines
    Polaris 220V 1.5HP QT blower
    12" elevation
    Spillway
    Spa fountain
    Spa light (1) Jandy LED
    Jandy PDA PS6 pool/spa control system
    $92,735.95
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: New pool build in Prosper, TX - looking for advice on these quotes
    Hi Odin,
    Welcome to TFP!
    all of those PBs you mention enjoy pretty good reputations in the DFW area. Im sure all of them would do you a good job.
    A couple of comments on the Gold quote.
    I see no need for upsizing the suction lines to 2.5 inches. There is no way a 2 HP pump would can pump enough water in a normal pool context to justify any extra cost associated with that.
    I might also recommend a 2 speed pump or variable speed pump instead of a single speed pump. It will save you a lot of electric costs and give you more flexibility to run your pump longer for skimming purpose without breaking the bank. Then you can bump it up on high for mixing chemicals or for whatever reason you might want to.
    As for the polaris 280, that cleaner requires an additonal booster pump to run it, (plus your filter pump has to run also at the same time). Not the most efficent way of doing it. I would recommend to do a bit of reasearch on different types of cleaners as there might be others out there that would fit you better. Having said that, the 280 works great and has a long successful track record. Just offering up other possibilities.
    The Rainbow 320 w/ Ozone system. Ozone is basically worthless when applied to an outdoor pool. They just dont live up to the hype.
    If you choose to maintain your chlorine using the TFP method, then the Rainbow Puck Holder wont do you any good either.
    A better option would be to either manually dose your pool with liquid chlorine, or incorporate an automatic liquid chlorine injection system.
    The Riverbend Quote
    The Variable Speed pump is a nice pump. No quarrel there.
    The infloor cleaning system is a luxury and carries a luxury price tag. It would be worth considering other options, such as a robot cleaner or polaris.
    Same goes for the rainbow/ozonator system quoted. They just dont cut it.
    The structural items on all the quotes look Ok as far as I know. Nothing sticks out that needs any investigation.
    As for the pricing, one way of doing some comparison is to divide the price by the linear feet. It sort of evens out the playing field a bit.
    The Gold quote is about 920.00 / linear foot.
    The Riverbend is about 850.00/ linear foot.
    If you were to compare apples to apples between the two companies, you may find you get a better price from Riverbend. Of course there are lots of variables and upgrades, but worth a consideration.
    I hope this helps get you started
    Im sure others will be along as well with some comments!
    Divin Dave,
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    I'm confused with this thread and another thread with the same title but with two different username owners. Or whatever you call it. Is this regarding the same pool build?
    Am I the only one confused?
    Suz.
    (don't mind me, I live in a state of confusion!)
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Suz,
    the other thread got split off of this one. The other one is a different person asking his own questions.
    Divin Dave,
    Apr 2015
    Houston, Texas
    3,217
    Thanks! That explains it.
    Suz
