Thread: Month 1!
    Aug 2015
    Whittier
    4
    Month 1!
    It has been a hectic one, but our new pool has been filled with water for one month! It took several weeks before our pool contractor added the start-up salt and chemicals and So Cal went through a scorching heat wave too boot. I have battled some green algae spots, but it seems that I am getting the upper hand.
    I have been keeping up with my testing and wanted to run the #'s by everyone. Do they seem OK?
    FC: 5.5
    CC: 2.5
    TC: 8.0
    CH: 425 ppm
    TA: 100
    CYA: 40
    Rob - 21'x34' / 3.5'-8', 7' spa, 24,000 G, Hayward 2.7 HP VS, 72 sq' DE filer, salt system
    Jun 2014
    15,255
    Re: Month 1!
    Hi Rob. Nice pool you have there. Your CC reading indicates that you may still have some organics brewing in there. Also, you didn't post your pH. With a new pool, you'll want to watch that pH closely. Because you stated you have had some green spots, and your CC is so high, I would normally recommend starting a SLAM (link below). Based on our Pool School - Start-up New Plaster, you should wait at least 30 days before doing a SLAM on new plaster. If it has been more than 30 days, then I would recommend a SLAM via Pool School - SLAM - Shock Level And Maintain.
    Your water is clear for now, so the sooner you bump that FC up to SLAM level (FC of 16) and keep it there, the sooner it should be done and you pass the 3 SLAM criteria. If you have ANY reservations about the higher FC level and any effects upon your pool warranty, please check with your builder first. You definitely don't want to go against their instructions in the beginning. But when it comes to eliminating algae, a SLAM is your best bet.
    Aug 2015
    Whittier
    4
    Re: Month 1!
    Thanks for the reply. I've been adding a pint of acid every other day and the PH has been testing at 6.8-7.2. Today it was 7.0. Chlorine tested at 3.0. Good news is that I cant see any more algae spots.
    Aug 2014
    Northern IL
    4,615
    Re: Month 1!
    Let us know about your warranty as you have some chemistry issues that need addressing.
