Results 1 to 10 of 10
Thread: Out of DPD - pool store had . . .
    Jun 2012
    Blaine, MN
    106
    We are in the processing of slamming our pool and ran out of DPD. Drats! While waiting for the order to arrive, I went to the pool store and they sold me DPD1Rapid by LaMotte - TesTabs. I had just a little left of DPD and did a control test and the tabs seem to be off by about 4 drops. I gotta say i am loving the tablets though. Anyone have an experience with them? Can I keep using them once the real DPD comes?
    We have put in 16 gallons of bleach since Tuesday or Wednesday. Does that seem excessive to anyone? Our CYA level was zero but I added in a gallon of liquid stabilizer and 1/2 pound granulated stabilizer with the sock yesterday. CYA is now testing around 40 so my target level is 16-20.
    Blonde Marcello
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Out of DPD - pool store had . . .
    Good question on those dpd "tabs".
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    No that isn't an out of the ordinary amount of bleach during a slam. I've read of a 95 gallon tour de force.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    30,432
    The solution turned pink when you added the tabs, right? Then you are good to go.
    Jun 2012
    Blaine, MN
    106
    Yay - it looks like the pool turned around over night. It's hard to tell for sure because it also rained 1" so the numbers are little off but the water is definitely more blue than green. Poured in the last bottle of bleach. On my way to get some more to keep an eye on it today. Should there be any concerns about people swimming in it tonight? Is the shock level of bleach bad for people? We've been trying to hold it at 20 for shock level.
    blondemarcello
    Minnesota
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    What we say is:
    If you can see the bottom clearly( for safety)
    If your FC is below or right at SLAM level
    If your pH is within the limits
    You should be fine to swim.
    It is suggested that you not use your best suit just in case. But in the end it should be fine.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    I find the use of the tablets to be a very interesting development. I see you did a comparison test already. Do you think you had enough left over powder for it to be a good test?
    Jun 2012
    Blaine, MN
    106
    bob, Yes I had enough leftover powder to do the comparison test. Still not sure if the tablets are accurate. Will check again when the powder arrives. I am liking the tablets so if they are accurate, will probably continue to use them. I will keep you posted on the results.
    blondemarcello
    Minnesota
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Thanks!
    Aug 2015
    Parkersburg, WV
    51
    16 gallons doesn't sound bad. I went through 80 gallons in three weeks during my slam.
    13,300 gal; AG; Hayward sand filter model S180T; Hayward power flo pump 60 gpm; Hayward Aqua Trol salt chlorine generator; city water.
    Rusty
