Thread: Scale cleaning
    Scale cleaning
    How do I clean scaling without having to empty the pool
    24' x 52" AG All Aluminum
    2hp 2speed 200sf Cartridge Filter
    Goldline AquaTrol
    4- 2x20 Sungrabber solar panels
    Goldline solar controler
    Re: Scale cleaning
    There is no straightforward way to remove scaling without draining the pool. There are various things you can try, but none of them work nearly as reliably as a full drain and acid wash.
    This page at Jack's Magic products has a good description of a no drain acid wash procedure. (The same thing can be done with out using Jack's Magic products, they just have a particularly good explanation of the procedure.) However, this procedure will usually take weeks, absolutely requires that the heater be bypassed, and even then it does not always work.
    Re: Scale cleaning
    How extensive is the scaling and how accessible is it? Also, what kind of pool do you have? That can make a big difference. If you only have a little and you can get to it easily you could try a pumice stone and a LOT of elbow grease if you have a plaster pool.
    I think a more important question is why do you have scale in the first place and what can you do to correct your water balance so it does not happen anymore.
