Results 1 to 11 of 11
Thread: Trying to fix an ancient pool pump, advice needed...
    Sep 2015
    Portland, Oregon
    4
    Hey there,
    I am currently in the process of trying to seal up an absolutely ANCIENT water pump... it leaks water profusely from the back of the shaft (between the pump and the motor). The motor itself works flawlessly, and aside from the leak, the pump works great as well. I am sure that almost nobody uses these anymore, but I am hoping that there is someone on this forum who has experience working on them from yesteryear?
    It was made by Robbins & Myers and has the following information printed on it:
    Before I fired it up this week, it hadn't been ran for at least 5 years, maybe even more like 10.
    Anyhow, I removed the inlet housing from the front of the pump in order to try and get at the seal that is leaking (the seal that is leaking is behind everything that is shown if the following picture), and I encountered this rather strange looking squiggly shaped impeller (correct term?) that doesn't appear to have any fasteners or method of removal.
    I took a close up picture of the base of the impeller (?) and it has a strange tabbed ring:
    Do I perhaps need to pry that ring up in order to get at what fastens the impeller?
    Does anybody know how I might remove that piece in order to get at the seals behind it? Furthermore, is there a method of reconditioning the seal without removing the shaft? Maybe some secret oil that makes the seal swell so that it takes up the space better or something?
    Thanks in advance for any input!
    Best,
    Casey
    Jun 2015
    Wildomar, California
    423
    Re: Trying to fix an ancient pool pump, advice needed...
    Hi Casey. Been doing pools since 1972 and can probably I'd the pump but I'm not able to view your pictures. Any other way I can view them?
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Wow! 1970 called an they want their pump back! Cool. Sorry, I'm of no help here.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Sep 2015
    Portland, Oregon
    4
    robdac: Yeah, I had a feeling I would get a lot of "just toss it and get something made this century" replies... I need to make this pump work, though.
    OldPoolMan: I sent you a PM. Not sure why the pictures aren't showing up for you, but I will email you them if you'd like.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I've been seeing folks stating that they cannot see pictures lately but I always see them. Not sure what is up.
    Very cool pump...hope you can get it working again.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    May 2009
    Youngsville NC
    395
    Actually, you can get a Pentair Dynamo 1/2, 3/4 or 1 HP (120 V as well) for not much over $200 . A Hayward PowerFlo II is also available for about the same. I've got a PowerFlo2 3/4 HP (from 1983) that I'm keeping as a spare (we salvaged it from a bathroom renovation) that I have actually used for a couple weeks on my inground pool.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Why do you need to make this pump work?
    Support the site
    Sep 2015
    Portland, Oregon
    4
    Quote Originally Posted by JamesW View Post
    aside from my personal preference for using older, well-built, self-serviceable equipment whenever possible, this particular pump fits like a puzzle piece into a complex infrastructure of filters/valves/rigid water lines/electrical conduit/etc. that would take a lot of time/money/sawzalling to revamp for a different pump.
    also, i try my best not to throw away things that work fine just because they need a (hopefully!) simple repair... at least whenever it can be avoided; and i really enjoy fixing things.
    of course, if getting at and replacing that rubber seal proves to be more trouble than cutting apart and revamping my entire pump/filtering enclosure, i will do so. hopefully it doesn't come to that!
    best,
    casey
    Are you sure that this is a water pump? I have never seen anything like it. I can't imagine that it could pump any significant amount of water. Do you have any performance specifications? How big is the pool?
    Support the site
    Sep 2015
    Portland, Oregon
    4
    it is definitely a water pump; it pumps water just fine. it can flow through a two stage filter and about 50ft of rather restrictive (3/4") piping to fill a 55 gallon drum in a little over a minute. i know that is probably pretty weak compared to most big modern pool pumps, but for a 1/4 HP progressive cavity water pump that is a few decades old, it really doesn't perform bad at all.
    anyhow, i just wanted to ask here on the off chance that someone might have had experience with a pump like this one, but if the pump is really so strange as to make people question wether or not it is in fact a water pump at all, it must be even older and more uncommon than i had realized!
    thanks!
    That will do 55 gallons a minute? That's more than I would have thought.
    Support the site
