Thread: Pump for solar failed..need advice!
    Jul 2015
    Honolulu, HI
    3
    My pool equipment is an unusual setup. I am not responsible as it came with the house. I have two pumps, one for the solar panels and one for the sand filter. The pump for the solar recently failed. My question is.. should I just replace the failed pump motor or is my other motor sufficient to filter the pool and push water through two 5 x 3 ft solar panels that are about 9 feet above the ground? I have a 10k gallon pool. Or should I get a new variable speed pump to do the job of the two pumps. Attached are some photos of my setup. The Sta-rite pump failed. The Century 3/4 HP is the filter pump. Between the solar panels and the pump is a Hayward actuator valve and the solar system is controlled separately by a Hayward Aqua solar GL-235. The rest of the system is controlled by a jandy Aqualink RS. I think most of the pvc pipe is 3 inch. Not sure why the two separate systems but probably to save money at the time. I would prefer to be able to operate the solar through the Jandy system but haven't figured out how to do that yet. I would appreciate any advice. My other equipment includes a pentair Triton II sand filter, Jandy AE-Ti heat pump and Polaris booster. Thanks!
    38,284
    Re: Pump for solar failed..need advice!
    Welcome to TFP!!!
    Can you please post a picture of the entire plumbing setup? Thanks.
    I would certainly consider consolidating into a single pump. Ideally a 2-speed version that your Jandy should be able to control and automatically switch to high speed when the solar is needed. What kind of PUMP is your century motor connected to? It is actually a 1.25 SFHP motor and depending on the actual pump it might have enough power to run the solar itself if you were not ready to upgrade to a new pump.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    what Jason said
    Jul 2015
    Honolulu, HI
    3
    Welcome to TFP!!!
    Thanks for your reply! I thought I would forget some key info. I am still learning about this pool and about proper pool care. This site has been an invaluable source of information. So the pump to the filter appears to be a Max-E-Pro Pool Pmp .75hp and the pump to the solar is a Max-E-Pro Pool Pmp 2HP. Could I just swap pumps and reconfigure the plumbing because it seems that the solar pump is more powerful? I live in Hawaii so the added automation that the Hayward Aqua Solar provides does not seem to be necessary since I like to run the solar and the filter at the same time during peak sun times. I would appreciate any suggestions on how to simplify my setup through the Jandy system. I would be willing to get a new pump/motor if necessary. I have provided a link with additional pictures of my setup. Thanks!
    http://khronos247.imgur.com/
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I have the Pentair IntelliFlo VA running my system and I have like 5 or 6 panels on the second story of my roof. My suction lines are 2" and the returns are 1.5". Are you sure you have 3" lines? That is a very large diameter and a tad unusual. Anyway, I can run my pump at the equivalent power of a 3/4 HP (2400 rpm) and the pump has no problems running everything.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jul 2015
    Honolulu, HI
    3
    Quote Originally Posted by Agent99 View Post
    Yeah I was mistaken. It's 2 inch pipe.
