Thread: Scale
    Scale
    How do I remove scale from my pool? Help!
    27100 gallon in ground Pool/Spa, SWG, Pebble Sheen-Aqua Blue, (All Pentair Equipment) Pentair VS Pump, Cartridge- filter, build completed Dec. 2013, Houston, Texas
    Jun 2014
    15,241
    Re: Scale
    Depending upon the severity of your scaling, and if there is more than just the pool surface involved, treatment can vary. For some, acid washing and or sanding/grinding have been somewhat popular. You may also want to read our page about scaling at Pool School - Calcium Scaling. As you can imagine, your equipment is also of prime concern, so keep a close eye on your test readings and CSI range, Hope this helps.
    You might like to read this thread as well: can I get rid of calcium scale without have to acid wash??.
