Results 1 to 8 of 8
Thread: Is it normal for one skimmer to have stronger suction?
    Jun 2015
    Dallas, TX
    148
    In the pool, I've got two skimmers at opposite ends of the pool, along with a main drain (well, a pair of main drains that are right by each other). Both skimmers certainly get suction and do a good job it seems, but one skimmer definitely has a bit more suction strength than the other. Is this normal?
    9,000 gallon IG pool with spa, Pentair FNS Plus 48 DE filter, 2HP Whisperflo pump, 0.75HP Letro booster pump, Polaris 280 cleaner, EasyTouch controller (originally a Compool LX100 that was upgraded via Pentair's upgrade kit), TF-100 kit
    38,524
    Re: Is it normal for one skimmer to have stronger suction?
    Depends how the plumbing was done. Certainly does not currently sound ideal. Any valves? Maybe need to adjust the float diverters under one of the skimmer baskets?
    Jun 2015
    Dallas, TX
    148
    On the pad there are separate valves (one for one skimmer, one for the other skimmer, and one for the main drain). They all look like they're set to full open. And I'm not sure what float diverters are - could you explain more?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    You probably don't have flow diverters since your skimmers and drain are plumbed separately back to the pump. If you want the skimmers to have the same suction it sounds like you can close the stronger skimmer valve a little bit.
    My two skimmers are plumbed together on the same line back to the pump. The skimmer farther from the pump and on the opposite side of the pool from the pump, has slightly less flow/suction than the closer one does. I assume because it is sucking water a farther distance. But, both get plenty of leaves in them.
    38,524
    I would close the floor about half way and then close the stronger skimmer until you like the balance.
    Jun 2015
    Dallas, TX
    148
    Dumb question, but when you say to close the floor drain, you mean just to adjust the skimmers, right? You'd open the floor drains back up after adjusting the skimmers, correct?
    Sorry, I'm new to all this. Thanks!
    DFW, TX
    24,514
    I'm thinking he means to keep the drain closed to divert more suction to the skimmers. I have a valve at the pump that controls flow between skimmer/drain and I keep it at about 80% skimmer and 20% drain because I prefer to have most of my water move through the skimmers for max leaf skimming.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Quote Originally Posted by lvrpl View Post
    You don't need them since somebody plumbed your pad well. Just put the word "float diverter" out of your mind because they won't even work in your setup.
    I concur with the other suggestion. Put the main drain valve at half way. Leave the weak skimmer full open. Close the stronger skimmer until the turbulence inside the skimmer wells match. Or toss a ping pong ball or some styrofoam peanuts out in front and see that they get sucked in at the same speed on both skimmers.
    The only time to have the main drain open full is when you're brushing a bunch of sediment or draining water using the pool pump. You'll have the skimmers shut then.
