Thread: Baking soda's impact on pH
    My current question is on the ABC's of Pool Water Chemistry article. There is a sentence that says " It is often best to make large TA adjustments in a couple of steps, testing the water after each one, as adding large quantities of baking soda can raise the PH a little and you don't want the PH going out of range.". Shouldn't the "little" be changed to "a lot"?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Baking soda's impact on pH
    The article is correct as it is written. Baking Soda has only a negligible effect on pH. Refer to the "Effects of adding chemicals" section of Pool Math
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    It is a very minor caveat.
