Thread: Trying to build aerator for pool but my jets don't allow a pipe thread?
    vt_tj's Avatar
    Aug 2015
    Salt Lake City
    3
    I need to get an aerator built into my in ground pool. I was already to get this project down last weekend. Stuck my hand down in pool to feel the jet had a thread inside it. I had assumed 1,5 inches. Went to Home Depot and bought all the pvc I need to make one of these elbow jets you can buy from amazon.com. Turns out the 1,5 pipe did not fit so I went back and grabbed a 1.25 and 1 inch to down size it to no luck. Turns out the thread actual is further into the jet and there is a smooth ID surface to the outside (towards pool) that is seems to be same ID as min thread ID. Thus I can't screw anything into my jet. I have attached a picture and let me know if this looks odd or familiar.
    Maybe I am going about this all wrong.
    thanks
    A 20,000 gallon pool, kidney shape in ground concrete pool, up to 7ft deep.
    Filtration - Triton TR-100 Sand filter
    Pump - Pentair WhisperFlow 3/4 Hp Model number 177449
    Pool Heater - MiniMax 350 gas heater
    Pump Timer - Manual dial timer on box. 2 way back flush valve.
    Jul 2015
    Western NC
    115
    Re: Trying to build aerator for pool but my jets don't allow a pipe thread?
    I ran into a similar problem when I wanted to reduce TA. I bought a fountain, but it didn't fit the Pentair returns.
    I tried both Lowe's and Ace Hardware for parts to make an adapter, to no avail. The Pentair threads seem to be between two standard dimensions.
    In the end I hooked the fountain up to our Polaris return.
    Maybe someone sells a Pentair to standard adapter that you can use.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    30,432
    I believe you will find two sets of threads in that return. The inner one (that doesn't fit) can be removed with a small "key" that engages two slots 180 degrees from one another. Once removed, you now have 1.5 inch female threads to engage.
