Thread: Adding a heater...maybe
    Jun 2014
    Houston, Texas
    475
    Want to make it through a second pool season. This year was weird.
    1. How much does a gas heater add to your bill?
    2. How much approx does it cost?
    3. Is gas better than elect?
    4. Solar panels....how well does that work?
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Jun 2012
    western NY
    1,559
    Re: Adding a heater...maybe
    Quote Originally Posted by DMS2014 View Post
    You will need to look on your latest gas bill and see what they bill you per Therm. A therm is roughly 100,000BTU. A 19K pool will need a heater sized at least 300,000 BTU so that will use 3 therms/hr roughly.
    Are you asking how much the heater costs, or how much it will cost to run? Heaters in the size range you need will run anywhere from $2500 $5,000 and up. Run cost is based on how much you use it
    Kind of like asking if Chevy is better than Ford. Both are good and have their application. electric heaters can fall into two catagories...Resistive and heat pumps. Resistive will bankrupt you. Heat pumps are fairly efficient cost wise but, you have to basically have them running all the time as they are better at maintaining temp than they are at raising it. Gas heaters can bring a temp up fairly quickly, Heat pumps not so much.
    Lots of info on this forum about solar heaters. In your area they probably work fairly well. The biggest drawback I can see about them is the space they need to install.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,763
    Your mileage may vary, but here in Michigan my (old Hayward gas) heater is allowed to run continuously to maintain 88 - 90 (88 if its hot outside...90 when nights and ams are chilly) and our average differential runs between $200 - $300 per month for the season...higher end on the shoulder months.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Apr 2010
    Central NJ
    227
    my bill is around 150 more a month on average and I keep mine at 87. Mind you though that I only run the heater during the weekends, as we are too busy to enjoy the pool during the week.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    If you have natural gas available it would be much cheaper than propane. Do you have just a pool or so you also have an attached spa?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    If you're in Houston, for the purchase price of gas heater or electric can probably buy you an installed solar system. (Fully installed, whereas the gas/electric will still need to be installed, electrician, gas company, etc.) Only cost to operate would be running the pool pump. If your pool gets too hot, just run solar at night to introduce cooler water.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
