Results 1 to 8 of 8
Thread: How far from house should the grill be?
    Sep 2015
    sacramento
    7
    I'm in the planning stages of an L-shaped island that will feature a sink and raised bar seating area. The island will be underneath my covered patio with one end of the "L" starting maybe just a few inches from the side of the house. Originally, I wasn't planning on adding a drop-in grill, but I'm going back and forth. My main grill is a six burner stand alone Weber summit, so I really don't need one. But, since I'm building an L-island, I was thinking maybe I include a grill.
    My island will be built with steel studs and cement board. There's no wood in my plans. What is (if any) a safe distance to install the grill from the side of the house. Or the fact that it will be under the edge of the awning and near they house just a bad idea overall. I've seen many pics online of folks having a grill in an island near the side of the house, so I'm wondering what your thoughts are on this.
    Thank you.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: How far from house should the grill be?
    A "permanent" installation may have to meet local codes. I'd start there.
    Jun 2015
    Houston, TX
    89
    In theory building code calls for 1 foot from combustible material.
    Confirm that for Cali.
    John
    AquaMaster Deluxe 8000 AGP, 5500 gallons, 12x18. Liquidator and Pool Rover JR.
    1st Pool so go easy on me I'm using a TF 100.
    Mar 2015
    Sugar Land , TX
    424
    I think mine is 1 foot from the brick wall. It sits in a cement board inclosure. No problems what so ever with heat on wall or surrounding stone
    Might have to zoom in to see grill
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    From what I can tell, this setup (a nice one, BTW) is similar to a few others I've seen. Nothing's jumping out at me as a hazard. Just be aware that the stone behind the grill will likely discolor over time due to smoke coming out the vent that I presume is between the grill lid and body. If that vent hood above the grill is functional, that will certainly help reduce the frequency of any buildup.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Quote Originally Posted by RemoGaggi View Post
    Thank you.
    Can you post a drawing or copy of your plans?
    Love TFP? Become a
    TFP Supporter!
    justinfrancisjudd's Avatar
    Dec 2014
    Temecula, Ca
    135
    in addition to your building codes be sure to pick out your equipment, they have specifics for clearances from non combustible surfaces to combustable surfaces specific to their product, my grill only needed 4" clearance non combustible, it was around 18" to any wood etc if anything was combustable behind that surface
    Justin
    2015 Build, Stonescapes Mini Pebble-Blue Sea, 46.5'x23', 9' deep, Paramount IFCS on steps and shelfs, 8' spa with spillover, Quartzite Flagstone Coping and Patio, 3" Suctions and Returns, 1 skimmer, 6 Jandy LED Watercolor lights, Baja Shelf w/ diving rock, 2x 2HP Jandy VS E-Pump, Jandy LXI 400K BTU Heater Cupro/Nickel exchanger, Cartridge Filter, Grotto/Waterfall/ Slide, Jandy SWG, I-aqualink 2.0
    Dec 2011
    Prosper, Texas
    124
    Quote Originally Posted by rphpool View Post
    this looks great but next time I would recommend you unbox the TV before mounting it.
    21,000 gallon pool w/spa, Pebble Sheen, Hayward EcoStar variable speed filter pump, Hayward DE6020 Filter, Hayward 400FDN Heater, Stenner pump with 15 gallon tank, Clear O3 ozone system, Hayward Goldline PS-8 controller, Hayward 6060 cleaner pump, Polaris 280 cleaner, Hayward EcoStar variable speed water feature pump.
