Thread: Why Aerate?
    Jun 2015
    Mesa, AZ
    22
    Why Aerate?
    Just wondering what if any benefits aeration has when it pushes your pH up and at least for folks like me, pH already tends to move higher over time, even absent aeration? Just curious. I've never used my aerator much due to the pH effect, but wondered if there was more to consider than that? Thanks.
    18k gallon in ground pool. Whisper flow pump, Pentair FNS 48 DE filter. Pool interior resurfaced with mini-pebble in May 2015. Kreepy Krawly Sand Shark Cleaner. Taylor 2006 test kit. Shade structure over shallow end of pool.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Why Aerate?
    Sure helps cool the pool about 5 degrees or so. Then knock PH back down with MA. Also a technique used in lowering high TA.
    Jun 2014
    15,259
    Re: Why Aerate?
    Aeration is effective when someone needs to increase pH only with no side effects to any other reading (i.e. TA). Pool School - Lower Total Alkalinity
    Oh yeah, and helps to cool the water.
