Results 1 to 12 of 12
Thread: New Hot Tub!
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    New Hot Tub!
    Just got this little hot tub, only 150 gallons!
    I read through the Bromine guide and I think I want to go that route. We had a hot tub in the past and never did anything except throw bromine tabs in.
    I was thinking I'd get a tab floater, and just do that along with start up powdered bromine. That seems like that's all there is to it, or am I missing something? I'll balance the other chemicals of course.
    They also sent these things with the Tub, what are they and why should I throw them out?
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: New Hot Tub!
    Ok so I re-read the sticky and the orange bottle is MPS. I can use it instead of chlorine to shock, am I reading that correctly?
    Test Kits:
    My Pool:
    May 2011
    The Netherlands, Europe
    49
    Re: New Hot Tub!
    Sorry, don't know anything about bromine tubs
    Sunspa Monaco in the garden since March 2011.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: New Hot Tub!
    Congrats on the new tub. Yes, that is mps that you can use to shock. I don't know a thing about that silver stuff. Except that I don't have any of it in my hot tub!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: New Hot Tub!
    The silver in combination with MPS is used in the Nature2 system as an EPA-approved disinfectant and I noticed the Nature2 logo on the silver product so I presume that is EPA-approved.
    However, that system doesn't use bromine, but normally uses chlorine "as needed" so usually once a week or two to keep the water clear.
    So you need to decide whether you want to use the Nature2 with MPS system for the chemicals shown in the photo or whether you want to go with bromine tabs. Those are really two different systems. Since you have the Nature2 silver with MPS, why don't you go with that unless you've already added sodium bromide for a bromide bank.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: New Hot Tub!
    Quote Originally Posted by chem geek View Post
    Thank you!! When I saw the nature 2 I assumed it was an unneeded mineral cartridge like their pool products.
    I read the manual for the silver system, and it says to dose weekly with dichlor or MPS. Is there any reason to use one or the other?
    Test Kits:
    My Pool:
    JoyfulNoise's Avatar
    May 2015
    13,199
    Re: New Hot Tub!
    Any reason why you wouldn't just use the dichlor-then-bleach method? Seems to me that any other method (bromine, silver, etc), is just going to cost you more money in the long run. I imagine the Nature2 silver stuff isn't cheap.
    Also, wouldn't it be a bad idea to use dichlor (chlorine) and silver together? Would the silver react and form silver chloride which is mostly insoluble in water? That's a reason to choose MPS over dichlor in my guesstimating.
    Matt
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: New Hot Tub!
    I'm lazy and looking for the method of least daily maintenance. The nature2 silver catridges are $30 every 4 months. Definitely more expensive than chlorine only, but not terrible.
    The manual says dichlor is fine, but tri-chlor is a no no. It's my understanding that the silver needs some sort of oxidizer to be effective, either MPS or chlorine.
    Test Kits:
    My Pool:
    May 2015
    13,199
    Re: New Hot Tub!
    Quote Originally Posted by pinguy View Post
    Hahaha....brutal honesty, I love it!!
    hmmmmm, well trichlor is much more acidic than dichlor and adds more salt than dichlor so perhaps there is something to that.
    Matt
    May 2015
    13,199
    Re: New Hot Tub!
    Well, it would seem that, rather than poking around in the dark, one should simply go to the source of all good pool & spa knowledge - John A. Wojtowicz.
    This JSPSI Paper should be required reading for all pool nerds....
    It would seem that using MPS with Ag+ ions produces both sulfate radicals (SO4-●) and divalent silver (Ag++) both of which are powerful oxidizers (see page 132 of the paper).
    Matt
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: New Hot Tub!
    Yes, the paper you found explains why the silver + MPS system works to be able to pass the EPA tests, specifically with the Nature2 product. That is why it is EPA approved and why I suggested it would be OK to use since he already has it. I have referred to this in many posts such as this one that refers to this post where I quote from that paper.
    As for chlorine producing silver chloride, it doesn't precipitate in the spa because 1) the silver is added slowly by chlorine oxidizing the silver and 2) any formation of silver chloride on the silver cartridge is self-limiting in that it is slightly soluble. This is intentional because the solubility of silver ions into the spa water will be limited by the solubility of silver chloride. That's how the system regulates the amount of silver and is also why the silver won't stain spa surfaces. Silver chloride forms silver chloride ion pairs (e.g. AgCl0, AgCl2-, AgCl32-, AgCl43- as described in the paper Thermodynamic Properties of Chloro-Complexes of Silver Chloride in Aqueous Solution). The net result is that the silver ion concentration initially drops and then rises again as a function of chloride ion concentration as I show in the table below.
    ppm Salt .. ppb Ag+ & AgCln1-n
    ....... 1 ........ 1167
    ....... 2 .......... 600
    ....... 5 .......... 260 ... 8 ppm FC results in 5 ppm chloride
    ..... 10 .......... 147 ... low chloride level in tap water
    ..... 20 ............ 91
    ..... 50 ............ 58
    ... 100 ............ 49
    ... 250 ............ 49 ... EPA recommended limit for drinking water
    ... 500 ............ 59
    . 1000 ............ 81
    . 2000 .......... 129
    . 3000 .......... 179 ... saltwater chlorine generators in U.S.
    . 5000 .......... 281 ... saltwater chlorine generators in Australia
    10000 .......... 561
    20000 ........ 1217
    35000 ........ 2445 ... ocean levels of salt
    Since most tap water has at least some chloride salt in it and since using chlorine will build up chloride, the silver ion concentration is naturally limited.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: New Hot Tub!
    I just wanted to say hi, and welcome. If you go with the Hot Spring Freshwater "Nature 2" cartridges that you can't use the cheaper Nature 2 branded cartridges, you must use the special Hot Spring cartridges as they have an extra lip ridge on the holder, placing a Nature 2 branded cartridge in a Hot Spring filter holder will fall right through and block water flow. I bought some off ebay cheap a while back that were advertised as for Hot Spring tubs, and turned out to be the generic Nature 2 cartridges, and had to re-engineer the extra tab with a zip tie to make them work.
    Ike
