Results 1 to 8 of 8
Thread: New Intex Plunger valves getting air in intake
    I had the old style plunger valves on my pool and they worked ok til they got old and stuck when trying to move them up and down so replaced them with the newer style and air is coming in thru it now and the tank the holds the cartridge won't fill up with water and bubbles are coming thru the out take hose. The intake valve is making a groaning sound and I can't leave the pump on for one minute without the air building up in the filter housing. I checked the dark gray connections under the turn on and off caps and they are tight. There is a little nozzle behind the turnon/off cap. Does it do anything?
    14 ft above ground intex with 2500 gph pump.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: New Intex Plunger valves getting air in intake
    That's where mine aspirated air, I hard plumbed with PVC soon afterward
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Quote Originally Posted by Piolin View Post
    Thank you for the reply but I'm afraid I don't know what this means. My only guess would be that the air wasn't coming from uour plunger valves and you replaced the hoses with PVC?? Mine was working fine with the old style plunger valves so if this is what you meant, I don't think it's the hoses in this case. We even put the old plunger valves back on and no air.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Yes, in my case it was the little black nozzle the culprit I put my finger on top and I was feeling the air succión
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Sent from my Nexus 6 using Tapatalk
    dakhath's Avatar
    Jul 2015
    Central FL
    35
    Those little black nozzles on the valves are vacuum relief valves.
    It sounds like you have faulty ones.
    They are a safety device to relieve excess suction in case the intake gets block by an object or swimmer.
    Did you try swapping them?
    They are just screwed into place.
    Take the one off of the return valve and put it on the intake valve.
    You only really need it to be on the intake for safety.
    If you feel confident in removing this safety device from your pool you could just take them off and plug the hole with something.
    http://www.intexcorp.com/11437.html
    Coleman 5300 gal 16'x48" AGP
    Intex Krystal Clear 2800gph Sand Filter Pump 28647EG (56673EG)
    Intex Krystal Clear Saltwater System ECO 8110
    Taylor K-2006 & K-1766 test kits w/ Speedstir and Samplesizer
    dakhath, Thank you. I will try this Thurs. when my son is here. No children in pool so I feel safe trying it. If that's the problem I will order new one. Keeping fingers crossed
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    I know i'm a little late but the valves should of come with a clear cap that you can put on the safety valves. If not i bought a variety pack of vacuum caps from the auto parts store and put one on mine and no problems. You could even duct tape them or wrap them with some plastic.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
