Thread: Do you secure the skimmer cover with screws when winterizing pool?
    Jul 2015
    Dayton/Maryland
    83
    I have a question, do you secure the skimmer cover to skimmer with screws when winterizing pool? If so, is it possible to make the ice inside to crack the skimmer house in winter time? Thanks.
    2003 Build 20K gallon salt water gunite IG pool, Taylor 2006 test kit, Pentair 011018 IntelliFlo Variable Speed Pump, Pentair IntelliChlor IC40 SWG, Aquabot ABTTJET Turbo T Jet Robot
    Apr 2010
    Central NJ
    227
    Re: Do you secure the skimmer cover with screws when winterizing pool?
    My pool cover sits on top of the skimmer covers so I always thought that was enough for me. As for icing, I use gizmos which not only plug the skimmer but they also protect the skimmer from the ice. You can also cut a piece of a noodle and jam it into the skimmer for added protection.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    May 2015
    Quebec, QC
    37
    The general idea is to minimize the volume which water could occupy in the skimmer body over the winter months. So you can add tightly fitting plastics ('styrofoam peanuts' in a garbage bag, pool-noodle like compressible packing materials ) right up to the skimmer cover. I would not fix the cover with screws; you may want to access it over the winter. I use horizontal plastic pieces in the skimmer throat and entry.
    14 x 28 Jacuzzi vinyl inground pool, Jacuzzi Laser 250 sand filter, Hayward 1 HP pump.
    Jul 2015
    Dayton/Maryland
    83
    Great ideas. The poolman used to put empty antifreeze bottle in the skimmer.
    Could you tell me in more details what the "horizontal plastic pieces" look like? Thanks.
    May 2013
    Fort Lauderdale, FL
    423
    You can use two partially filled RV antifreez bottles. One in the bottom, and the second wedged at an angle to hold it all down. Last year I bought a "gizmo" from amazon and it's the way to go. Cheap and works great. Plus it acts as the plug too so in the spring you don't have to reach down into the goo to pull the skimmer plug.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
