Thread: Help with Startup
    May 2015
    keller
    129
    Help with Startup
    I am an owner builder and I started my new pool 36 hours ago. Pump running at 1500 RPMs (speed 2) 24/7. This is a pebble plaster. ~17K gallons
    TA 100
    PH 7.3-7.4
    Chlorine 0-1
    CH 150
    I have 3 trichlor tabs in each skimmer. Questions:
    1) Should I be concerned at this point with my chlorine being so low?
    2) Should I be concerned about CH being too low?
    3) Should I begin to add CYA?
    4) I ordered a chlorine tab floater from Amazon that will be here tomorrow. Should I use this to fill with the trichlor tabs instead of putting them in the skimmers? If so, how many tabs should I put in?
    Thanks!
    Owner Builder; Under construction, 17K Gallons SWG IG Geometric; 31X20'; 600sf; 104ft perim; depth 4'-6'. Sun-shelf; bubblers; sheer descents; Dolphin M400; Pentair Intelliflo XF; Clean and Clear 520; Easytouch 8; IC40; 2 color LEDs; TF-100, K-1766, SpeedStir
    Jun 2014
    15,004
    Re: Help with Startup
    Standard replies (in order) to your questions would be as follows:
    1 - Yes, increase FC per Pool School - Chlorine / CYA Chart
    2 - Yes, adjust per Pool School - Recommended Levels
    3 - Yes, add per Pool School - Recommended Levels using the Poolmath calculator . For a SWG pool, your CYA should be between 70-80.
    4 - No. Unless on vacation or away from your pool for an extended amount of time, do not use tabs/pucks. They increase CYA to an unmanageable level. Use regular liquid bleach to increase your FC until your SWG can maintain the required FC level somewhere between 3-5ppm.
    After all of this however, if this is newly plastered pool, please read this page first: Pool School - Start-up New Plaster.
    Hope this helps.
