Thread: Pool Water Evaporation Rates
    Mar 2007
    San Rafael, CA USA
    12,082
    This WaterEvaporation spreadsheet will calculate the evaporation rate given air and water temperature, relative humidity, and wind. Note that this is the wind speed at the surface of the water which is usually quite a bit lower than general wind speed due to fences and the water being somewhat below ground level.
    This post shows some of the relative effects for these different parameters where wind speed is the most important.
    JoyfulNoise's Avatar
    May 2015
    13,171
    Re: Water Evaporation Rates
    This is great! Thank you for posting this.
    Matt
    Jul 2015
    South Africa
    8
    Re: Pool Water Evaporation Rates
    Thanks for sharing Chem Geek
    +- 45000 Litre IG, Fibre Glass Pool, 1 HP Pump, some sort of Sand Filter, Sunny South Africa, TF-100 test kit
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Thanks for posting that spreadsheet. It agrees very well with my actual measurements.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
